Safety reminder - RETORQUE YOUR UBOLTS............
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Jan 15, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Not as seemingly important as safety glasses but still important. ]Re-tightening your ubolt nuts to the proper torque. Did the one ton conversion in late May of 01, and retorqued the wheels and ubolts three times during the first month, and one other time. Well went back through the whole truck's suspension last weekend during a maintenance/grease job thrashing and noticed 3 of the 16 bolts were rather..................loose. Not loose as in finger tight but loose as in not torqued to anything near 150 lb/ft.
    Just thought this was worth mentioning, since I did the retorque thing 4 times since the conversion.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;&lt;a target="_blank" href=http://www.blazzinor.rockcrawler.com/&gt;BlazzinOR's Beast Buildup&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by BlazzinOR on 01/16/02 09:41 AM.</FONT></P>
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    Re: One more safety reminder..............
    good tip.things tend to loosen up on trucks...especially ones that vibrate down the road on boggers,ect
  3. BurbinOR
    5,829
    Oregon
    TTT - think its important based on my experience.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    That's why I use red Loc-Tite on all my u-bolts. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    150ft/lbs seems kinda tight dont it, I think 115 to 120 would be good enough wouldnt it. I think on my buddies block kit it said to go around 105ft/lbs.
    On my truck, both sets of springs I have put in, I have torqued them to 120, then drove it for a day, then retorqued them and they stayed torqued. Ran the first set for 1 1/2 years and they were okay when I changed them.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yes on a block kit i can see it being lower. cast aluminum is weak. it keeps things from cracking.
    i dont see a problem with 150ft lbs. seems a bit tight. but i work on helicopters and we use some WEAK TQ's for some things you would think would be as tight as the biggest wrench can go. so 150 seams kind of weak at the same time. think of how much TQ you are putting out at your wheels. LOTS.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  7. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I dont think I have seen a Cast aluminum block kit before.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, not sure I would want loc-tite on them. How do you retorque them when they stretch? Seems to me, that's what causes the need to retorque.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i have some. not on my truck. blocks are good for one thing in my mind. keep my truck from rolling away while i have it torn apart. i have not really looked at other blocks. but most of the ones i have seen are cast. never paid attention to what they are made of. but mine are Alu.
    Grant
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I have some 8" blocks out back. Hmm, I think I've still got some 12" too. In fact, I've got a pair of 8" blocks under the front of my truck now. Everybody complains that blocks under the front are not safe but, I disagree. I think it's much safer with them under there...
    Russ
