sagging doors...best way to fix
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Jun 29, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    any body have some input??? obviously my left door sags more than the right. i hate the way they drag when i open and close them.
    thanks rob
    AIRBORNE!!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If they aren't rusted out, new pins & bushings would probably do the trick alone. If not, they're easy to adjust.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  3. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    how do i adjust them....i would look in my haynes manual....but. none of the good stuff is ever in there.
    AIRBORNE!!
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Typically GM's sag the most on the bottom hinge - Loosen the bolts on the hinges where they mount to the body and pull up the rear corner of the door. It's trial and error from there - usually you can expect 4 tries before you get it right.
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Ya, I think you'd need new pins and bushings, or if they're worn enough, new hinges. I got them once from the dealer for $8, upper and lower driver's side. The whole hinge (upper I believe), on the other hand, was $200 from the same dealer. Pins and bushings were fine, just a bit of a pain to install.
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  6. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    SLAM THEM REALLY HARD!!!!!!
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  7. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    had the same problem. replaced the hinges with brand new GM, only to find out the door metal was torn just outside the area where the upper hinge bolts. dont have to worry about that now. :)
    still have the hinges, if you are interested...
    MTPockets
    <A target="_blank" HREF=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</A>
  8. Grim-Reaper
    7,385
    Atlanta
    They sell hinge pin kits at Auto Zone and Pepgirls in the Help section. Pretty cheap.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  9. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Take them off and make soft doors.
  10. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Best fix is new bushings from the HELP section at the parts store. Bring a friend to hold the door while you install the bushings an then adjust the door. You CAN do it by yourself, but your neighbors will laugh at you and you may show up on America's Funniest Home Movies.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Can you replace them with the doors still one, with someone holding the door up, or do they have to come off?
    90K5
  12. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I need some hinges what do you want for them and wich ones are they??
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can do it without removing the doors - Just do one at a time - If you don't have a small hammer that fits in between the door and the jamb, get one - If you don't have one, it's almost guaranteed that the pins won't want to seat in the new bushings.
