sagging jimmy
Discussion in 'The Garage' started by rescue1, Oct 30, 2003.
  1. rescue1
    rescue1 Registered Member
    Oct 30, 2003
    5
    i need to know what year i can swap my sagging leafs with?
    i have a 87 with the quad shock front end. i want more susp
    to help in those extrem times /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/1zhelp.gif
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Viagra and/or Britney Spears are the best cures for a sagging jimmy that I know of.
  3. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Im just glad theres no pictures /forums/images/graemlins/eek.gif
  4. rescue1
    Oct 30, 2003
    5
    i tried the viagra and i had stiff steering all week
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am assuming your truck is most likely sagging in the rear end? If so you can buy 1" add a leafs for the rear springs pretty cheap and should level your truck out. Depending on how bad the sag is...just an idea. Check them out here $40 ORD 1" add a leaf /forums/images/graemlins/thumb.gif
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I've been looking at the different options for while. I finally went with an add-a-leaf from the local 4x4 shop. It cost $60 and lifts the back right up. I was worried about how it woud affect my ride and flex but I ran it up a dirt ramp and it flexed just as good as it did before (my shocks are likely the limiting factor). Anyway, it also helps with all the crap I'm carrying in the back (chains, snatch block, winch, tools ...)
  8. rescue1
    Oct 30, 2003
    5
    thanks for the info but its the front thats sagging. ive never seen a chevy front with only two leafs in it. what els can i try?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  9. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    all blazers/subs/trucks either came with a 2 or 3 leaf spring pack i beileve...same with the trucks..depending on if its a 1/2, 3/4 or 1 ton...im not sure on a 1 ton though..
  10. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Maybe get some 3 leaf springs from a local junk yard? /forums/images/graemlins/confused.gif
