sagging my a$$ HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Mar 27, 2001.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    ok heres the thing i have a six inch lift in the front that i made my self and in the rear i put a 3 inch block cuz i figured that the front would eventually sag to a 5 leaving me with a big version of a stock k5 which i liked but after giving it time the front has not sagged so now i want to even it out 6 in the front 6 in the rear and my ? is should i do an add a leaf on top of my 3 inch block or a add a leaf on top of 4 inch block you see i want it even not higher in the back than the front and thats my consern and ORD is not an option $$$$$$
    NOT ALL HISPANICS DRIVE LOW RIDERS :-)
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Did you put new springs in the front? How did you do the front? Lifts that you buy replace the new springs and the rear (if you put blocks on them) usually sags about 1-2". Usually a helper spring will fix that. If you didn't replace the front springs then if you put a 6" block in the rear it should sit like it did when it was stock. I hope this helps.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I had that problem, then I just bought the ORD, and 1" add-a-leaf's. Looks awsome now, but my rear springs are bad so i am buying stock replacement springs.
    [​IMG]<font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red>
  4. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    front i did a 2 inch add a leaf for a jeep which for a leaf over jimmy gives you 4 inches then i got an add a leaf for the rear of my buddies 93 bronco turned it around 180 and opened up the hole where the bolt goes through and that gave me 2 inches a total of 6 inches up front and very smooth ride and awsome flex. the back has just a 3 inch block and some cheap tricks for the rear flex so now i want 6 inches in the rear with a 2 inch add a leaf but should i keep the 3 inch block or use a 4 inch block cuz i know 6 inch kits come with a 4 inch block and a 2 inch add a leaf but how does that look
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    do you or can you get pics of your setup i would like to see how you did the front
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  6. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    i dont have any good close up pics of the front suspension but you can see something go to jimjim.coloradok5.com and check out the photo gallary mine is the orange 75 convertable
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    clickable:
