Sagging rear... need a little lift.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cookeb, Jul 31, 2002.
  1. cookeb
    cookeb Newbie
    Jul 22, 2002
    3
    Lexington, NC
    I have the typical sagging rear end due to the towing that I do. What are the options for adding about an inch until I can afford a REAL lift??
  2. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    You should get your springs re-arched. That will pick the a$$ right back up. Or you could buy those 2" blocks that are being sold in the sale section. /forums/images/icons/smirk.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    One quick simple solution, ORD Zero rate leaves. Rearching will work but it is not permanent.
  4. dyeager535
    26,979
  5. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    zero rates work for me... /forums/images/icons/laugh.gif
    J
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    Plastic surgery is expensive, but can take years of sag from your rear. For a short term quick fix, you could try control top pantyhose or the handyman's friend, duct tape.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I used some old overlaod leaves I had lying around. Put them in right under the rest of the pack. Needed longer center bolts though. For about an inch with a firmer ride, put them in as usual, but for less, like maybe 3/4" flip them upside down and you'll keep your ride good
