Saggy asses
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazentank, Apr 18, 2001.
  1. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    I just put a 4 inch lift on my 86 k5 i used a procomp lift with springs in front blocks in rear. but the back is sagging down 2 inches in the rear i've herd that the blazer's had the saggy ass syndrome but don't know what is the best solution I just need help because it has htis stupid looking stance even though i have 32's on back and 31's on front so if i din't have the 32's on back there would be a 3 inch differance please help me
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Get some helper springs that will correct for 2 inches and put them in the back. This is common
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I too have an 86 and when I installed my 2 1/2 lift my ass sagged too. I got a pair of add-a-leafs from 4WPW and it raised it up so now my rear end is higher. Actually it sits just about level. When I take te top off it does go up.
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  4. dyeager535
    26,980
    http://www.dorianyeager.com/index2.html
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    They make 2 inch also. You can also get an easy ride helper spring. It's real long instead of short and basically re-arches your springs, which is what they need.
  6. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    Or just get new springs for the back that will match the front.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Or you can go with a 2.5" ORD Shackle flip!
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  8. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    I had asked about that when I got my lift kit. I was told that if you put blocks in the back instead of springs that it would sag.
    '85 Jimmy in Jax, Fl
  9. CK5
    May 19, 1999
    21,624
    702
    CO
    ORD can make these in any size you want (with in reason) and they did not make my ride any harsher.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  10. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    not that 31's and 32's are TOO big a difference, but doesnt stuff get messed up with different size tires on the same diff ratio's?
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>
    <font color=red>SIGN MY GUESTBOOK!</font color=red>
  11. 84K5WITHAJUNK305
    84K5WITHAJUNK305 Registered Member
    Feb 25, 2001
    41
    Denison TX
    Yes, different size tires with the same gear ratios can cause damage, don't do it.
    A broken 84 k5 and lots of mud, it sucks to be me
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Its probalby OK off-raod only, especially in the mud, but i wouldn't keep it like tha tlonger than necseeary.
    90K5
  13. Daveytree
    Daveytree Registered Member
    Nov 11, 2000
    57
    Kingman Arizona, U.S.A.
    When I lifted my truck I noticed what I thought was a sag also. What I found out is that the rear fenders are cut lower than the front. The front are cut higher so they will have clearance when the truck is turning on a bind. My truck was actually sitting level. It was just an illusion. I don't know if this is your problem or not. It is just what I noticed.
    [​IMG]If you don't like my driving, <font color=red> get back on the road.</font color=red> [​IMG]
  14. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    You could also just put in and add-a-leave in the rear. I've never had a problem with mine.
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  15. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    To get an accurate idea of your trucks actual stance make sure it is parked on level ground and measure up to the body line. If you're measuring the fender openings you'll be way off. The body line should be level to the ground...within reason.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  16. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'm assuming you could throw a little level on the top of the rig also...
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  17. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    I simply used a level at the body side molding that runs front to back.
    I had a poll at one time to check the height at each wheel! The easiest way turned out to do as above!
