Saggy butt
Discussion in '1936-Present Suburban' started by nevercomplete, Jan 25, 2003.
  1. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    My suburban, like a lot I've seen, has a saggy rear end. I'm wondering the best way to fix it. What would be best, add leaves, new leaves? I'm open to suggestion. Thanks
    Jon
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Well, ideally I want to replace my rear springs with new lifted springs, but until then i fixed my saggy butt with some zero rates /forums/images/graemlins/thumb.gif
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i like my saggy butt but mine is intentional, 7" lift front and 6" rear i like the way it looks personally. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  4. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    my 2wd sags because I've actually fractured several leaves in the packs... one of those problems of having a 454, and usin the loud pedal too much. I just plan to throw springs from my parts truck under it, ( preferably before the ones that're under it crack out, and leave me sitting on the side of the road, )
  5. Ddragggon
    Apr 25, 2001
    2,657
    I say go for it. engine mounts can't be too hard to either fabricate, or have fabbed up, and if the tranny adaptor is only $65, then I don't think its that big a deal. if you can get the accesory mounting brackets off of it, then you'll not have to worry much about finding them.
    good luck with it,
    -Rich
  6. nevercomplete
    Dec 25, 2001
    309
    Much to everyone's dismay, I do not plan on lifting this truck. This is my tow vehicle and daily driver. Please don't hate me /forums/images/graemlins/frown.gif I'm just tired of the rear of my truck sitting low like it is. Thanks for the suggestions.
    Jon
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I got a set of ProComp Add a Leaves to pick the rear spring pack up. It was the 1.5" to 2.5" leaf. I've had it in for over a year now with no problems.
  8. nevercomplete
    Dec 25, 2001
    309
    Probably the course of action I'll end up taking.
  9. chvyhs
    Feb 12, 2001
    1,469
    What are you doing in Japan? USMC?
  10. nevercomplete
    Dec 25, 2001
    309
    That's it.
  11. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    If none of your leaves are cracked you can get the springs re-arched. Thats what the previous owner did to mine and people always think I have a 2 or 3" lift but I dont. Stock Burb's were higher bakc then than people give them credit for.
  12. nevercomplete
    Dec 25, 2001
    309
    How much does getting the springs re-arched run? Who does something like that?
  13. afroman006
    Aug 21, 2002
    2,876
    No idea about the price but obviously its less that a new set of springs . I would guess a machine shop could probably do it. Not real sure on that either.
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You need to find a shop that makes and sells springs. It isn't cheap, especially if they have to take the springs off the truck. I've read that re-arching only lasts a couple of years before sagging again. It makes sense to me, since rearching doesn't change the original spring rate, it just puts the curve in them again. /forums/images/graemlins/frown.gif
  15. nevercomplete
    Dec 25, 2001
    309
    Thats kinda what I was thinking. Whats to keep the springs from sagging again?
    Jon
  16. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Just go with the 1 inch zero rates. Your springs are sagged already do this would lift you to level and you wouldn't have the problem again. plus its only 40 bucks!!! /forums/images/graemlins/grin.gif
  17. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Springs that get re-arched after time lose the arch. If it's for towing like you say, do an add-a-leaf because it'll firm up the ride in the back which will be better for the towing. The best add-a-leaf I've seen is the Superlift one. It's in between a short and a long and is just right.
  18. nevercomplete
    Dec 25, 2001
    309
    Excuse my ignorance, but what exactly are zero rates?
  19. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  20. nevercomplete
    Dec 25, 2001
    309
