Saggy rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Jul 6, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Do Blazers actually tend to sit with the rear lower than the front, or is it an optical illusion because the front fenderwell is bigger? I've seen this on my 83, plus other Blazers with brand new lift kits. I'm leaning toward the illusion explanation, but it's still annoying anyway. I wouldn't mind having it sit a little higher in back anyway, so it would have some room to sag when loaded.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the top adds a bit of weight and generally makes them sag.. you can toss in a zero rate or small cut down leaf spring like a block to make it a little more even...
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    why the saggy butt look is cool! my sub sags about 1" and wen i get back to vegas for another round of mods next year its gonna sag more wen im done, about 8" of lift on the front and 5-6" on the rear. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    only reason muddysub's is gonna sit higher up front is because hes gonna pull the motor to add some clear wire looms while the 700r4 is out of it... lol
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    don't forget the gas tank sits well behind the rear axle. I currently have my gas tank, top, and tailgate off and my rear sits a good 4" higher than the front.
  6. muddysub
    Jun 23, 2001
    10,451
    489
    [/ QUOTE ] the 700r4 isnt in my sub, hell no. its got a th400 which i love. the motor does need to be yanked though, once i move back to vegas next fall that'll happen. oh and i'll get some clear tail lights too. /forums/images/graemlins/thumb.gif
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Why not just sell your Sub and buy a pre-runner if that's the look you're going for??? Saggy butt looks STOOPID IMHO, buy hey, I'm an old-timer, and all these young-uns like the saggy-aced look....To each his own I guess...
  8. dyeager535
    26,975
    I doubt the K5's came stock with a saggy rear, but it's the fact that the rear springs aren't designed to carry a lot of weight, the gas tank is behind the axle, and it's huge/heavy. So thats why they end up sagging so much. (as do the Suburbans)
    But...if you look closely at the trucks (measure) the front wheel well opening is a different shape (higher than the rear) and the body line isn't parallel to the ground for it's whole length. So that can screw up your perception of the truck as well.
