saginaw psp ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by digity, Apr 21, 2007.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    Is this unit an upgraded pump that simply replaces the stock one with no mods? And is it a better pump for the price? I'm running 36tsls and need to replace my pump for the second time(which is a real pain) in 15months. Thanks for any feedback.:eek1: :bow:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I don't understand?
  3. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    Unless I'm mistaken, factory GM = Saginaw.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Jason, saginaw is the style of pumps that are used in our trucks. What is wrong with yours that it needs replacing?
  5. digity
    Oct 10, 2004
    184
    13
    Brentwood Ca
    It appears to b leaking from the rear/resevoir side. I'm assuming from the seal. from what I understand there kits where u can replace pumps only or u can replace the whole unit pump with resevoir which is what I did last time. My original Q. was if there aftermarket pumps( complete with resevoir) that are better than others. The one I have now is from napa.
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    all the pumps u buy from a parts store will be about the same, arg & some others manuf. high volume/pressure ones for rock rams. u can mod one to make it do the same.
    if yours is leaking from the resevoir it may only need a new o-ring, either in the housing under one of the bolts or on the pressure line coming off the rear.
    if u are not having steering problems, u prolly don't need a new pump.
