(Same old question) what Tire size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bad_bo_ti, Feb 17, 2001.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    I have an 84 blazer, with 6in suspension 3in body and cut out flares, its more of a daily driver than an offroader, what is the biggest (i want wide too at least a 14.5 or wider) tire i can fit without tire rub?
    thanks
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    If you don't wheel it too much you could probably get away with a 38x14.5 in those wheel wells. Of course there is a lot more to it than that, you'll have to regear, at least 4.88's with a non OD tranny and maybe even 5.13's with OD. Even with the right gearing you should make sure your tranny has an adequate cooler. Then there is axle strength to consider, the 1/2 ton stuff does not fare well with larger than 35" tires. How about braking? Those big ass tires have a lot of inertia, and the 1/2 ton brakes aren't exactly huge.
    Rene
  3. bad_bo_ti
    1,027
    OhiO
    hey man i am switching over to a 14 ff in the rear, i will probably regear later on too. thanks for the input
  4. CK5
    May 19, 1999
    21,625
    702
    CO
    Here is my take on the question, if your tires don't rub they are to small. Get bigger ones and trim untill they just barely touch. [​IMG]
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    Amen, brutha.
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>[​IMG]
  6. bad_bo_ti
    1,027
    OhiO
    hey that would work if i didnt already have cut out fender flares on it.
  7. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    I think 39.5s could fit as well
    [​IMG]K5[​IMG]
