same old questions sorry
Discussion in 'The Garage' started by nstarry, Jan 12, 2005.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    Hey just a little confused let me start here
    I have been researching re-lifting my K5 and found that aftermarket springs are 2 1/2" wide and stock are 3'' wide Is this true for the rear springs? because i thought I had a 4" lift but my rear has 2 1/2" wide springs and 3" blocks (roughcountry) my rear springs have a real good arch to them not somthing you would thik to see in a 30 year old rig. sholud I think that its a 6" lift ??
    Second is the 52'' front spring swap that easy ? 6 rivits in each front hanger drill and re-bolt done !! and I have looked but is the total lift 4" or does the spring give 4" and then the longer rear shackle give another 1 1/2"or 2" (71/4"shackle)
    these are probably stupid questions but sorry
  2. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    gm rears always are 2.5" wide at least 63-87 anyways
    rears 88-up appear to be 3", at least the set from a 97 at the yard i saw the other day anyways
    dunno other years
  4. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    so then I am fitting 35x12.50x15s with no rubbing at all on 2" s of lift wow!
  5. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    88-up spring info
    the rear 88-up springs are still 2.5" wide. and are 64" eye to eye. i have done a swap from 56" to 64" springs for a softer ride and more flex from the length.:cool1:
