same wiring plug?
Discussion in 'The Garage' started by knudel, Jul 29, 2004.
  1. knudel
    knudel Registered Member
    Aug 26, 2002
    Salem, Oregon
    So i'm not finding the answer to this.. in converting from a 6.2 to 350, can i simply use the whole engine bay wiring harness from the gas blazer i'm taking the 350 ot of and just plug it in, since they appear to have the same plug at the firewall? Common sense says no, but... would be alot easier than going thru wire by wire and removing the diesel ones, and then not knowing if some diesel sensor being gone's gonna affect the gasser starting...
    Any ideas? Thanks guys.
  2. dyeager535
    Knowing GM, everything on the fuse panel is probably very similar, if not exactly the same.
    Personally I wouldn't attempt it without a pinout of the diesel and gas fuse blocks, just to make sure. I guarantee if they are the same year they WILL go together, but no telling what you could possibly fry by putting the wrong halves together.
