Sand blasting media Q/...EZ off-oven cleaner Q...
Discussion in 'The Garage' started by 84gmcjimmy, Jul 15, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay I am starting to look for parts I need to sandblast my project blazer. I am getting Aluminum Oxide (50LBS) to get all the rust and grime off the frame, then I was thinking walnut shells for the tranny/transfer case.(MAYBE 50 LBS) What would I use for axles? If you have a different suggestion please tell me. I don't have any place local so I have to get it off the internet.
    I will be getting the media from eastwood.com
    Thanks for the help. /forums/images/graemlins/peace.gif
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Re: Sand blasting media Q/...
    I used sylica(sp) sand on my frame. It's been months since I did it but I think I used over 200 pounds. Probably closer to double that. My local lumber yard has it in house. $8- #100 In my opinion the media you are planning on using is way to expensive for the frame. Make some calls local and try to find some other options, shipping will kill you /forums/images/graemlins/crazy.gif espesially shipping to Canada...
    As for the trans and t-case the walnut shells would probably work very well, just make sure the cases are clean of grease and oil first. Remember the media will get Everywhere even if you seal these cases I'd be willing to bet there will be media inside after your done. Just somthing to think about. I used a wire brush on my 4" Makita for my axles, cheap and easy. Have fun /forums/images/graemlins/grind.gif
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What else could I use to get the tranny/t-case cleaned right to bare metal? I don't want to risk getting the internals all messed up.
    Sylica sand? Is that 8$ per 100 pounds? Thats probably best then, especially if you said you used over 200 pounds for yours. The aluminum oxide I was going to get is almost 50 dollars per 50 pounds /forums/images/graemlins/yikes.gif
    Will the sylica sand work for the axles too? I will also use a wire brush too.
    One more question, is it Oven Cleaner that works good on getting the oil, etc off the frame and axles? Thanks
  4. Stomper
    May 11, 2002
    3,767
    Iowa
    Wire brush, elbow grease /forums/images/graemlins/whistling.gif On my 203 gear box I used sylica but I stripped it down to an empty case.
    Yes
    Yes and no....You still take the chance of filling your axle with sand....not good /forums/images/graemlins/doah.gif
    I think it is EZ Off...I've never used it so mabey someone else will chime in. /forums/images/graemlins/peace.gif
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I'll wirebrush the tranny/t-case.
    I don't want sand inside my axles! so I will wirewheel the axles.
    And I will call the lumberyard places tomorrow and see if they have any sylica sand. (Do they come in bags, or how do they come?)
    Then, if nobody chimes in about the EZ off oven cleaner I will make a new thread /forums/images/graemlins/eek.gif
    Thanks for the help /forums/images/graemlins/peace.gif
  6. Stomper
    May 11, 2002
    3,767
    Iowa
    ya, they come in 100 pound bags....better start lifting weights /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    eeek. I hope I'll survive. Thanks for the help /forums/images/graemlins/peace.gif
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Will EZ off-oven cleaner, clean the dirt and oil off my frame? Can I use it on my tranny/t-case and axles too? Is there anything I should be aware of before using, thanks /forums/images/graemlins/peace.gif
  9. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    oh boy will it ever!
    i used a can on my front axle housing and as i was wiping it off i was shocked that it was a dull raw metal, it literally ate everything!
    it wouldnt hurt to hit the axle with a presure washer first to remove the big stuff tho
  10. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    If you use silica sand, be sure to get a respirator (I don't trust the dust masks). That stuff is bad for your lungs. Oh, and it gets everywhere.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Where can I get the proper resperator? I don;t care about it getting everywhere, it will be in the backyard ontop of the dirt.
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you should be able to get a resperator no more that 25 bucks at a hardware store. here the sand is $4 for 80lbs /forums/images/graemlins/peace.gif
    if you can do it on concrete, blacktop, etc you can sweep it up and reuse it. /forums/images/graemlins/deal.gif saves money. just remember to use a screen to get out the chunks. i use a window screen /forums/images/graemlins/waytogo.gif
  13. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    hey have you check to see it there is a princess auto out there yet? they have media ans sand blasting stuff cheap!
    i would not cheap out on a resparator, you get what you pay for, this is mine i got for free from my last job /forums/images/graemlins/peace.gif
    you can get them at safty suply stores full face is about 120 and a half face about 60 70 bucks there your getting quality, i don't like some el cheapo versions companys put out for homedepo shoper
  14. diesel4me
    Jul 24, 2003
    17,561
    940
    Massachussetts
    I get sand at wal-mart or home depot for 3 bucks a bag--its labelled as "play sand"--intended for kids sandboxes--seems to work pretty good,50 lb.bags.I tried being cheap and usind sand swept from the street in front of my house--but you have to sift out the pebbles and other junk so it wont clog,and its usually wet,and its a pain to dry it out.I tried beach sand from a beach near Plymouth mass--bad idea! Salty sand is great for making more rust than you removed--the paint falls right off after a few months,with a healthy dose of salt induced rust undr it--it seems like the salt goes right into the pores of the metal,where they do the most damage! /forums/images/graemlins/angryfire.gif
    You may want to make some kind of "tent" or similar thing to do your blasting in--my neighbors are pretty anal about the clouds of dust settling on their new trucks and cars--one threatened to sue me--I told him I would stop doing it out in the open and made a "greenhouse"PVC pipe tent to do my sandblasting in--also told them to never drive that truck,all the sand in he street will ruin it! /forums/images/graemlins/rolleyes.gif-- like a little dust was going to hurt it from 300 feet away! /forums/images/graemlins/tongue.gif
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Darkshadow, we don't have a princess auto here. I doubt I will beable to find a resperator locally. I;m in a jam again /forums/images/graemlins/dunno.gif
    I will be sandblasting over top of a tarp, so I can reuse as much as possible, then the rest I will just dump on the dirt. I will probably put up some type of wall so I don't get sand in the pool, and in the neighboors yard /forums/images/graemlins/yikes.gif
    Does anyone know of a website I can look at resperators specifically for sandblasting? All I can find is ones for sanding and painting /forums/images/graemlins/dunno.gif
  16. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Yeah when I first started sand blasting I tried to use play sand but it clogged all of the fittings in the system. I even sifted it out first with some very fine screen. Then I found out that Northern Tool and Equipment Co. carries 50 IB bags of the stuff for 3 bucks. Just as much as I was paying for play sand. LOL Anyways, yeah the stuff works awesome and is called black diamond, which I use for everything. Stripps rust off of metal like nothing.
    Remington
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Does anyone know where I can get the proper resperator online?
    Can I use the EZ-off oven cleaner on my frame to get dirt and oil etc off? Can I use it on axles and tranny/t-cases? Thanks
  18. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    DON'T use oven cleaner on aluminum! It will oxidize it in a most nasty way. Also, don't get it on your paint, it'll eat that too. Oh, and your skin.
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What can I use on the tranny-tcase then? Just a wirebrush I guess...
    But I can use it on my frame and axles though?
  20. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    When you use the oven cleaner, just make sure you wash all of the residue off, and you should be fine using it on your frame and axles. If you don't wash it off, paint won't stick to your frame correctly, and it can cause rust problems.
