sane pricing NEW D60s
Discussion in 'The Garage' started by bigjbear, Jun 23, 2005.
  1. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Anybody notice that little blurb in 4Wheel & Offroad about Ford possibly offering NEW front D60s for arround 3k? Or even the F450 versoin w/ the bigger ring gear and heavier knuckels for a grand more. Yes, I know they are balljoint style, drop on the wrong side, and new Fords use coils up front. But spring pearches are easy to make and there are tons more x-fer cases out there that work w/ the other drop. This might make places like Boyce & Dynatrac take notice.
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    one can only hope I guess. Dynatrac etc are pretty spendy, but that has made room in the axle building industry for some lower priced competition to sneak in there and get some of the market.
    j
  3. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    But who'd of thought that one of the "Big 3" would be the lower priced compition!
  4. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    That would rock if it's true. No, wait... THAT WOULD ROOOOOCCCCCKKK!
    T-cases are easily adapted. Even ORD's big green thing is/was running a Ford case. MOOAHAHAH.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I dont think it is that good of a deal.
    You could spend $1000 on a Chevy D60, all new bearings, gears, and locker and still be under 3K. Plus you have kingpin knuckles which are super easy for crossover, and you have Chevy 8 lug which are super easy to find wheels for.
    Am I missing something thats so good about them being NEW?? :confused:
  6. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    Wheels are a good point those axles are probably 8x170 and its very hard to find wheels for those trucks unless you want to buy weld.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    I agree... $3k for D60 front is too much even if it is new. Hell even if you had to spend $1k on a D60 and then drop another $1k into it to rebuild it, you'd still be $1k ahead of that price with a stronger axle.. And you dont have to change spring perches and a look for a drivers drop t-case...
  8. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    article said they were considering offering them a retrofit for the IFS (I assume they ment TTB) trucks, which means leafsprings and 8 on 6.5. If they only offer them in 8 on 170mm that would be a bummer.
  9. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    There are a lot of people spending $2500 for 20 year old front axle from places Boyce and twice that for a new axle from places like Dynatrac. If nothing else this will keep prices from getting even higher. As far as a L/H drop case goes, they are a lot eaiser to find and normally have fewer miles than the R/H drop cases. Most GMs since '88, All GMs since '92, all Fords, Dodge since '94. Plus, if you're doing a Doubler Ford NP205s are super easy to find and all com w/ the required 31 spline input. Anyway, just my $.02.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    But you could find a used axle alot cheaper and rebuild it yourself for under $2k...(depedning on the buying price). Plus the kinpin axles are stronger and you dont need to change the t-case.
    Granted changing the t-case isn't very hard and they aren't usually hard to find. But then there is more money you have to spend...
  11. tacoma
    Jan 14, 2005
    317
    tooele UT
    In many places 60's are kind of hard to get ahold of. I don't think $3k for a brand new one is that bad. Not that I'd spend it, but it's not a bad price.
