SAS 97 4 door blazer
Discussion in '1983-2005 S-Series models' started by K1Orion, Jan 13, 2004.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I've got a 97 4 door S-10 blazer that is dying to be molested. I was thinking about doing a solid axle swap, using a 14FF and a D44.
    So has anybody put a solid axle under a newer S-10?
    I would imagine leaf springs would work but any body done a link setup?
    Any info is appreciated, especially pics.
    AND, are ZR2 fenders the same as regular S-10, just with bigger flares?
    thanx
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think a 14 bolt will be way too wide if you want this to be a street legal ride. /forums/images/graemlins/frown.gif S-10's are pretty narrow rigs. Your tires will be hanging WAY out of the fenders. Jeep Wrangler axles are closer to the correct width, and I think some of the front ones even have the diff on the correct side to match up with your stock t-case.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Jeep axles. and ther once was a coil kit through fabritech, it used coil and links.
    zr2 fenders on the frist models were just hacked fenders with big flares.
  4. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I was thinking 14 bolt from a dually, I'll have to find out its wms-wms #s. I'll look into fabritech, thanx.
  5. beevee
    beevee Newbie
    Jan 12, 2004
    3
    A better axle selection and donor vehicle for that swap is a 76-77 Bronco. The dana 44 front axle will have disc brakes and the width is comparable to the Blazer. That is what I was looking into prior to buying my K5.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    anybody got a link to Fabritech, or know where to contact them? please PM me if so.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Hard part will be doing the ZR2 cut-out flares on the rear wheel arch. The rear doors come really close. Might have to lengthen the wheel opening, and move your axle back. IIRC, the 14bFF from a C&C is 62-63" or so - same as a YJ I'm told /forums/images/graemlins/whistling.gif
