SAS clearance question
Discussion in 'The Garage' started by thezentree, Apr 18, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    i was under my truck the other day and i noticed that there is hardly any room for the front driveshaft to angle down. the transmission crossmember is in the way, and im just curious as to what you SAS guys did to get around this. /forums/images/graemlins/dunno.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Mine clears with tons-o-clearance, I am only running 4" springs though. When my front axle droops way down to it's max I still have 1/2" of clearance.
  3. thezentree
    Sep 19, 2003
    7,198
    NC
    would the crossmember be farther forward on a yukon? im only gonna be runnin 3" or 4" springs as well, so its not gonna be that steep of an angle
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Should be the same, when I first looked at mine before the swap I thought there was no way the shaft would fit but the yoke is far enough out from the tcase that the shaft clears just fine. How far is it from the centerline of the yoke to the front edge of the crossmember?
  5. thezentree
    Sep 19, 2003
    7,198
    NC
    its about 8"
  6. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    Dont you use the older style c-vjoint with a flange mount
    driveshaft, This shoud move the pivot point out away farther i think???
