sat for 3 weeks, won't start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Dec 21, 2001.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    sat for 3 weeks, won\'t start
    what's the most likely cause of this, and what do you do about it, it cranks fine, but it won't spark, where do you start checking for missing spark?<P ID="edit"><FONT class="small">Edited by coolhandluke on 12/21/01 12:50 PM.</FONT></P>
  2. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    Re: sat for 3 weeks, won\'t start
    Depending on what type of distributor you have, check to make sure you have juice going to the coil. Check your coil, and if everything is good, pull the boots off one at a time and hold them next to the block, it's easier if it's a little dark, and see if you have fire through the wires, you might also want to check wire resitance. How are your spark plugs? How is your distributor cap and rotor if it's cracked or corroded, it could definately create some havoc! It soulnds like you have lost the juice, check form the coil back all the way to the battery, just remember, you have to have power to it. And most impotant, don't overthink it.
    &lt;*)))&gt;&lt;
    81" GMC Jimmy, 4" lift and a shackle flip, and 35's!
    IT'S A DOG EAT DOG WORLD OUT THERE, AND I'M WEARING "MILK BONE" UNDERWEAR!!!!!!!!
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    How long did you crank it for? It could be that the gas in the line from the tank to the engine evaporated. Is there any sign of gas going to the intake?
  4. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    I've definetely got gasoline flowing, just no spark at the plugs
    83 k5 originally diesel, now 350, 700-R4 12 bolt rear, 33x12.50 BFG Trails (yuck), desperately seeking a lift
    sometimes nothing is a real cool hand
