Saw It All?
Discussion in 'The Garage' started by big_o_blazer, Aug 11, 2005.
  1. big_o_blazer
    big_o_blazer Registered Member
    Jul 13, 2005
    13
    north carolina
    hey ive got a question when yall sawzall wheel wells what do you do with the inner fenderwell cause i want to cut ALOT but the inner fender well will only allow me to cut like an inch all the way around in front and a few inches in rear. Im getting an 8 inch lift want to run 42-15" any suggestions
    75 k5 under construction
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    you will have to cut out the bottom part of the inner fender...you can modify your stock ones to make them larger essentially...just use some sheet metal or the like.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That's just about where I've cut mine. I used a sawsall from the outside then a 3" cut off tool (disc cutter) for the rest. I then turned and beat back the edges so I had no sharp edges hanging out.
