Sawsall the fenders, what about corrosion?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Mar 11, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    My wheel wells are all rusted out (they got more worse in this pic BURB ) and I want to cut off the rust to prevent it from spreading so fast. Also to make room for bigger tires, but im not worried about that now. How would I prevent the edges from rusting after I cut it? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    the quarters at the bottom are two pieces of sheet metal. all you need to do is tap them together and weld them then spray paint. if you cant weld then clean up th sheet metal and jb weld them. but make sure you spray them with spray paint and that should do it.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    add a lip to the bottom.
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    my new metal was "seam sealled"??? whatever the hell that means....it was suppose to prevent water/salt/mud from getting between the metal- and therefore prevent in rust...ask me in 5 years if it worked
    Brandy
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I just keep mine clean as much as possible
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Brandy
    On most new cars the body panels are spot welded where they meet and seam sealer is used to make them water tight.
  7. MudNurI
    Jul 15, 2001
    2,113
    VT
    all I know is the body guy recommended it- and charged me appropriatly!
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you will like the nice price he charged you in 5 years.
    grant
