Sawzall + Grade 8 bolts = lots of dead blades
Discussion in 'The Garage' started by SS66, Jun 4, 2005.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Hey guys, I havent been here in awhile Everything looks WAY different. Anyhoo, I got a 1/2 inch grade 8 bolt that I need to cut with a sawzall. ( no I do not have access to a torch ) I purchased 10 Milwaukee Metal blades rated to 1/4 inch. Well all 10 of them didnt even make it completely through.. I had to bust the remainder loose. Anyway what Im getting at is does anyone know of any QUALITY blades that will actually last? I thought Milwaukee would be good but I guess I was wrong.
    Thanks!
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I use the Dewalt bi-metal blades for bolts, sheet metal, etc. works pretty good. and If I just need to tear some **** up, I get the Milwaukee "AX" blade, not that great for metal, but it tears **** up.
  3. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Im thinking about buying a grinder and getting some cutoff wheels. Ive never used one but I imagine its a better bet than the sawzall
  4. 3rdshiftdesign
    Feb 6, 2005
    259
    Bucks County, PA
    Just make sure you get good grinding discs with your grinder.
  5. 79_hootie_k5
    79_hootie_k5 Registered Member
    Mar 11, 2004
    23
    columbus, ohio
    Lenox blades are the best ones I have used.
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Blu-Mol Xtream Demolition and Rescue Blade.
    That worked for me.
  7. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    Hi five on the replies with the good blades ! Sawalls are good where no sparks are needed . Get a grinder with a cutoff wheel ,that will rock !!! harbor freight has them on sale for under $ 20.00 .
  8. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Thanks guys.. I dont know if Im going to invest in blades or just get a grinder. In the end they will both be about the same price ( cheap grinder )
  9. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    I have had good luck with Morse brand blades-especially the Fire and Rescue line. However, grinder with a 1/16 cutoff wheel has worked best for me with cutting larger bolts or an air cutoff tool.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i buy the dewalt 18 TPI bi metal blades in a 10 pack for like $10, they work great and last somewhat, and the best part is they are cheap.
    for demolition i have a milwaulkee 14" demolition blade with a variable tooth count. i can go threw lots of stuff fast. my buddy and i were cutting an old camper trailer off for the frame. he had a 6" metal blade on his and i had my demolition blade on mine. we started on the same time at the front and worked our way back. i was done with my side before he got half way and he had the side with the door.
    it was all aluminum with wook paneling under the siding and the inside.
  11. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Has anyone ever used the blades that have grinding grit (like a grinding wheel is made of) instead of teeth? How do they work?
  12. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    Lenox is the best for fine line cutting through most metals
    Magna Demolition blades are very good for hacking, i have a two pack that has sent 7-8 cars to the shredder, with more to go.... Lifetime warranty too!
    Metabo or Tyrolit blades/wheels for cutting/grinding
    Grit, AlOx are really only for cast iron, stone, brick, fiberglass and other small particle material, they dont have the chip removal for solid materials like steel or aluminum
    Cut slow, and use a lubricant, ie: wd-40, oil, atf, theres some really good stuff called STICK-CUT thats in a grease tube package w/a wax like consistancy works good in all positions. Good blades work. let them do the work dont force them, you can cut 100s of ft with a crappy blade or you can toast 10 good ones on 1 bolt, its all up to you
    i distribute stuff like this and can give you guys some good deals if shipping doesnt kill it.
  13. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I got a 10 pack of 18TPI blades from Lowes, don't know the brand. But anyways, they cut right through a tie rod with no drama.
  14. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    Those blades with the "grit" on them are excelent for HARD metal. The ones we use will cut through grade 8 bolts and locks just fine.
  15. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    never used the gritty blades but a couple of guys were right when they recommended Lenox brand blades.. all sawzall blades are not created equal! The milwaukee blades are junk IMO.. Go w/ Lenox...
    mike
  16. toomanytoyzz
    toomanytoyzz Registered Member
    Apr 16, 2005
    27
    Havertown, PA
    I know you said you have no access to a torch, but if you stick with working on cars I'd highly recommend investing in one. They make life so much easier when you're dealing with stubborn bolts. The sparkle wrench has saved my sanity time and time again.
  17. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    few years ago Milwaukee was hands down the best,
    but they seamed to have truned to crap, so we baught every blade on the markit EVERONE, then we when out and got another 50 pack of Milwaukee, because even though they arent top noch anymore there still the best.
    used to make ornamntal iron fence and railing ect. and we cut a lot of stuff on site with the sawls all belive me
  18. diesel4me
    Jul 24, 2003
    17,559
    940
    Massachussetts
    I've tried all kinds...
    I've used Milwaukee blades,Black and Decker,Bosch,and many "dollar" blades I bought at flea markets and swap meets for a buck apeice..the best of the "cheapies" were a brand called "Aggressor" ,they seemed to cut good and outlast the other brands quite a bit...havent seen any around lately though,the guy I get them from must have retired or croaked! :blush:
    I settled on Lenox blades after I had one given to me and it lasted so long I thought it was titanium or something!--I cut up whole truck frames with 1 blade,and even after I folded it in half and snapped the "chuck" end off,I was able to bash it with a hammer straight again,and I ground a new "tab" on the chuck end,and clamped it back in and sawed even more stuff with it!....Then the clincher was when I learned thats what the Fire department here uses on their sawsall for rescue work...the only bummer is they are pricey--but like anything else you get what you pay for,and they outlast many cheaper blades 3 to 1,so in the end its actually cheaper to buy the "good" stuff...
    Same goes for cutoff wheels and grinding discs--3M brand is best,but also costs the most--but they are worth the money!..the thinner,the better when cutting bolts...using a grinding wheel to cut bolts works,but strains the motor badly,and leads to early failure...
    I've been using my arc welder to cut up some heavy (1/4") frame beams!--since I'm better at blowing holes in stuff than welding it with the arc welder,I figured I'd try it as a cutting device....I soaked some 6011 rods in water for a few minites,and cranked it up to 200 amps...I was able to cut 3-4 " before it tripped the curcuit breaker,had I a better 220V source,I'd be using it more than my torches to cut the heavy stuff up--they make cutting electrodes that work decent too,but are costly...makes an arc welder into a hilbilly plasma cutter!...it works amazingly well for how crude a setup it is..and no oxogen to run out of when the welding shops are closed... :crazy:
  19. gambit420s
    May 17, 2005
    294
    i didnt have much luck with grit blades on some 4340 1" sq bar but a 24tpi lenox blade made 4 cuts and still looked ok
    and "locks"? most are only case hardened for shock resistance
  20. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
