Sawzall Question
Discussion in 'The Tool Shed' started by Bubba Ray Boudreaux, Mar 27, 2005.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Do they chew through 1/4" plate pretty good????????????
    :hack:
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I've just been doing that yesterday and today. Yes when the blade is new, though it dulls fairly quickly. Use some oil to help keep the blade cooler. It will last alot longer.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Not too bad. It is important to buy a good blade though. Once I bought some crap Makita blades that hardly cut tin. Milwaukee and DeWalt blades cost more, but they last longer and cut faster, and would be the best bet for 1/4". How many linear inches do you have to cut?
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    It's faster than a hacksaw but slower than a plasma cutter.
  5. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Heck, that's the question of the week. I'm trying to postpone the inevitable by buying tanks for the torch, $300 + and figured if a Sawzall can do what I need better than the jigsaw :D and yet cheaper than the torch, then I would get one.
    First item to be hacked would be a winch mounting plate, so it wouldn't be all that big of a job.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Don't remember the brand name (it's pouring rain or I'd go look) but the important thing is they are/were bi-metal blades. They last longer. These are about 8 inches long. And make long cuts, not edge ways, it goes faster/straighter. IMO.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    got a angle grinder?? Just use a cut off wheel on one, will cut faster and make better cuts :)
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    :haha: :haha: :haha:
  9. kevcarr59
    kevcarr59 Registered Member
    Nov 9, 2003
    35
    Austin, TX
    Angle grinder..
    Much cheaper also..
    Just bought 4" Angle grinder from Harbor Frieght...On sale for $8.99.. Reg price $20... A lot cheaper then SawzAll... :grind: :grind: :whistle: :whistle:
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    If y'all screwballs want to cut plate with a friggin 4" angle grinder, go right ahead. I'd rather listen to 4 hours of John Kerry and his plans for America..............................
    :deal:
  11. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    :haha: :haha: :haha: :haha: :haha:
  12. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Ive done both, and they both work, but the grinder method sucks for cuts of any length or when you need them to be somewhat precise.
    Ill take a sawzall with a good quality blade over a grinder for accurate cuts. A sawzall with a good blade makes a much nicer cut and is easier to work and keep in a straight line.
  13. divorced
    Jul 20, 2004
    5,115
    [John Kerry voice] I have a plan... [/John Kerry voice]
  14. diesel4me
    Jul 24, 2003
    17,581
    945
    Massachussetts
    both methods work...
    The sawsall is ok as long as you have plenty of sharp blades handy--1/4 inch thick plate will dull them fast,especially if they are too fine or cheap ones--use "Lenox" blades for best results,they last a lot longer than the cheap ones,thats all the fire Dept.here uses on rescue work involving a sawsall..you can bend them in half,and just smack them flat with a hammer and keep on sawing!--they do cost a bit more,but they are worth it!...
    I've used abrasive wheels made for a circular saw to cut heavy plate,it works pretty good,better than you'd expect from a woodcutting type of saw,it turns it into a metal cutting monster with one of those abrasive blades--it will likely take 2 or 3 of them to go much farther than a few feet on something that thick,but it might be faster than a sawsall...easier on you too..
    Those blades are around 3-4 bucks each at home depot or Lowe's..makes a nice neat cut too,no grinding--the angle grinders work,but are slow on thick stuff,and eat lots of wheels..better for tin and body work.. :crazy:
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I've done the same thing with a circular saw. Just bought blades for a chop saw. Worked great, although I agree that 1/4" will eat them fairly quickly. It also gets very hot - make sure that there are no holes in the fingertips of your gloves. :weld: :yikes:
  16. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    If you can find the sawzall blades that say "the torch", I've cut a lot of 1/4 wall tube with those with good results.
  17. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Noise?
    "If y'all screwballs want to cut plate with a friggin 4" angle grinder, go right ahead. I'd rather listen to 4 hours of John Kerry and his plans for America....................."
    You will listen to a grinder anyway to clean up the sawzall cuts
    the sawzall cuts fine but it will leave the edges looking rougher than doing it with a grinder and some cut off disks
    Have you cut plate with a sawzall? ,do you realize it also is very noisy?
    Just my own exp.
  18. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I wouldn't................ :yikes: :D
  19. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Milwaukee makes the "Torch" blades. I have cut A TON of metal and steel with those blades, including red iron structural stuff. Good choice. Lenox is good stuff too. A little oil goes a log way to making ANY blade last.
  20. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I did the same thing last year with a jigsaw. Bosch preditor blade. It cut the crap out of the 1/4" metal with good lines.
