SB 350 roller cam block?
Discussion in 'The Garage' started by hidesertwheelin, Mar 29, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    How do I tell if my 350 Sb from my 90 Suburban is set up for a roller cam? There is a rounded ridge that runs down the middle of the lifter valley with 3 tapped hopes in it. Thanks.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes that is a roller block the taped holes are for the lifter guide retanier
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Also the tops of the lifter bores need to be machined flat, if not then you would need a retro-fit roller cam and lifters.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes but the top of the lifter holes need to be machine flat. Not all blocks are setup like that.
