SB400 rods
Discussion in 'The Garage' started by Muddytazz, Jan 31, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    A small block 400 comes stock with 5.565"rods. I'm going to be rebuilding my 400 here shortly and am trying to figure out what/why the benefit of upgrading to 5.7" or 6" rods? Is there really any added benefit to doing this?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Forget the 6" rods, they're not practical for a street engine in my opinion.
    The reason to go with the 5.7" rods is rod angle. It reduces the side loading on the pistons (reducing bore wear) and also prolongs the time the piston stays at TDC and BDC. It is theorized that this will result in more power, although not really proven to be significant.
    If I was intending on building a street 400 that I wanted to last a long time, I'd use the 5.7 rods. If I wanted a budget motor that I was going to use on the trail, I'd likely use the 5.565" rods. If I was buying pistons already I'd definitely go 5.7".
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    What he said. The 5.7" rod is better in every aspect (except you have to scavenge some rods from a 350). Better power, longer lasting engine, etc.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll hop on the bandwagon and recommend the 5.7 rods too, but only if you are buying pistons. If not, the 5.565's will work just fine.
    I'd stay away from the 6.0" on a street motor due to the fact that the compression height (wrist pin location) leaves the oil-control rings somewhat unsupported.
    400 piston with 6.0" rod:
    400 piston with 5.7" rod:
    I just like the support under that oil-ring. I'd rather have a bit more durablity and peace of mind in a street/DD motor.:waytogo:
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I've got 5.565" rods in my 406 and no problems.
  7. 1977k5
    May 26, 2003
    9,995
    133
    Of course you have no problem. We are just saying that it is such an easy mod that it is worth the roughly 1% gain in power (I saw a very complex program that compared the three SBC rods and what power they would make) and the better engine wear.
