sb406 cam?
Discussion in 'The Garage' started by pismorat, Jul 24, 2004.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I am looking to do a cam shaft in my SB406. It is stock spec right now, but I have built the motor with good pistons, intake, modified stock heads, and other components. I hear the cam is holding me back. What company do you recommend? And what lift/duration would you run if you wanted the most power, not much worse mileage, no more engine mods, and if it still had to pass Smog every two years? Thanks. /forums/images/graemlins/truck.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The best thing to do in my opinion, would be to call CompCams and tell them the info on your motor and they'll get you the best cam for what your looking for /forums/images/graemlins/thumb.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Cam is definetally something you need to change to make some more power. Comp Cams is where I'd be looking. As for emissions, no idea, I'm no where near CA and have no idea how your testing goes.
    http://www.compcams.com/Technical/CurrentCatalog/HTML/128-169.asp
    I'd say the X4250H, it is the mildest 4x4 Extreme Energy cam. Maybe rjfguitar will reply, hes always going on about his badass 406 and hes from CA.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Comp cams part # cca-12-210-2 which is the high energy 268H cam. It is about the biggest cam you can get that comes with a carb # and it works excellent in my 406 and it sounds like your motor is basically built about the same as mine. It's a good cam with a mild idle that lobes just a little but makes tons of torque from about 2000-5500 RPM's. Good throttle response and I get about 8-12mpg. /forums/images/graemlins/waytogo.gif
