sbc 262??
Discussion in 'The Garage' started by 74757685k5, Nov 19, 2005.
  1. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    any one used one of these?? do they bolt up like all other sbc?? and is it worth it?will it go in place of a 350 with clutch?
    it will go in somthing stock. truck or blazer w/235/75/15s.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Mid 80's junk!! don't bother!
  3. diesel4me
    Jul 24, 2003
    17,567
    942
    Massachussetts
    not junk--but not good either...
    They used the 262 V8 in Chevy Monza's..a great motor for them,a lightweight car..not good at all for a full sized truck..its close cousin the 267 V8 was used in El-Camino's,Malibu's,and some early 80's Impala's..they were great on gas,I had an 80 El Camino "Royal Night" SS that had one,and got 22 mpg on the highway--it had a 2.56 posi rear,and I could get it up to 65 mph in low gear before it started to wind out--it was a slug on takeoff,and couldn't spin the tires unless they were on sand or ice!..I would not use one in a 4x4 or fullsized truck..its a gutless wonder,couldn't pull the foreskin off a misquito!.
    :p:
    I put a "305" and a "TH350" in a friends truck about 5 years ago..I suspected it was not a 305,because it had a tiny harmonic balancer,and a weird 2 bbl carb..so I "decoded" the numbers on the block--sure enough,it was a 267! :doah: --the 82 Impala that the motor came from evidently had this 267 swapped in--the tag on the radiator support said it was a 305--either that or GM lied!..and the tranny turned out to be a TH250! :doah: -
    The 82 C10 I put it in also had 2.56 gears,and it was sluggish too--but better than the 250 six and wimpy Monza style 5 speed it came with originally..(it was a telephone company truck originally!)..it ate the lobes off the cam in less than 3 months after the motor swap.. :( ..what a wasted effort!--at least the 350 was easy to put in after the 267 went in--they are identical externally.. :crazy:
  4. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    262 = 4.3L
    The V6 4.3 probably puts out more power too.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    According to Google, the 75-76 262ci SBC has 3.671 bore and a 3.1 stroke. It probably has more balls that a 267. :p: You would have to check the starter bolt pattern to see what size flywheel you can run.
    If you are looking at downsizing for economy, IMO, a 283 is probably your best 'small ci' smallblock.
  6. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    262 = 3.671" x 3.10" (Gen. I, 5.7" rod)
    265 = 3.750" x 3.00" ('55-'57 Gen.I, 5.7" rod)
    265 = 3.750" x 3.00" ('94-'96 Gen.II, 4.3 liter V-8 "L99", 5.94" rod)
    267 = 3.500" x 3.48" (Gen.I, 5.7" rod)
    283 = 3.875" x 3.00" (Gen.I, 5.7" rod)
    Journals -
    265...Mains-2.30"-Rods-2.00"
    283...Mains-2.30"-Rods-2.00"
    Year Casting CID LoHP HiHP Main caps
    1975 355909 262 110 110 2
    1975 360851 262 - - 2
    1979-82 471511 267 - - 2
    1955 3703524 265 195 _ 2
    1955-56 3720991 265 195 225 2
    1979-82 14010280 267 - - 2
    1979-82 14016375 267 - - 2
    1979-82 14016376 267 - - 2
    1979-82 14040205 267 - - 2
    I've got a bunch of random info on my wiki if you want to dig more into it
    http://ke5bvc.info/wiki/index.php/Engine
