sbc 400 built bottom end
Discussion in 'Engine | Tranny | T-case' started by sweetk30, Jul 29, 2006.
  1. sweetk30
    Nov 1, 2004
    25,555
    548
    horseheads , ny 14845
    i have a used 400 sbc with a built to the hill bottom end. balenced/blueprinted/polished/debured/knife edged crank/smothed and balenced rods. 2 bolt main with 30 over pistions. motor ran super strong when i got it. pushed my 6500lb 1ton all over the country side. ran 210 all the time on the stock gauge in dash. never went abouve till i spun the water pump belt off and over heated it .
    bad: needs crank and rod work. played just a bit to hard one day and just started to smoosh #1 rod bearing in cap. NO IT DIDNT SPIN!!! it just started to press out the sides by a 1000th or so.
    and from motor being apart in back of garage needs cylinders honed . slight surface rust. and i noticed 2 diffrent styles of pistions but super close to the same all around.
    heads are all remaned 76cc heads.
    i was told if i wanted to make her run to swap on a set of 64cc heads and the motor would sing.
    make me a offer and come and get it for the right price. pm me please thanks.
  2. sweetk30
    Nov 1, 2004
    25,555
    548
    ttt needs to go now!!!!
  3. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    If you were only close to texas.
    bigred81
