sbc crossmember for a 69-72
Discussion in 'Parts & Trucks Wanted' started by shaun, Mar 4, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    i need a engine crossmember for a smallblock in 69-72 is it the same as a bigblock. Caan I use one from a newer truck. If not I need one
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I did not have to change the cross member when I put the big block in my blazer.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    they are same 63-87 2wd trucks blazers burbs panels, its just the engine mount brackets that changed, there are 68-71 styke and then 72 unique one year only ones and then 73-up but all same engine cradle, just holes changed a little, and yes you can use X member from 5 through 30 series truck 63-87, only reason why ppl take them from 71-up trucks is for the disc brakes conversion
    good luck
