SBC Valve sequence question
Discussion in 'The Garage' started by rafterman191, Nov 27, 2006.
  1. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    I found the answer to this question a month before I needed it and now I can't find it on the net anywhere. I need the intake/exhaust valve sequence in a sbc. Cyl# 1,3,5,7 are IEEIIEEI for purely example (I don't know if that is correct probably not).
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    EIIEEIIE is the sequence from either end of the head, this goes the same for the passenger side as well.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Another way to adjust the valves is to turn the motor over to TDC (both valves closed on #1) and adjust both valves on #1. Then rotate the motor 1/4 turn and adjust #8. Continue through the firing order until all the valves are adjusted.
    I like this method better because it assures both valves are closed regardless of how much duration the cam has.
  4. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    Another way of adjusting them is turning the motor over until the adjacent valve is just starting to head back down its lobe, then you adjust the other valve.. like this, do number 1 first, wait until no.1 intake is coming off its ramp, then do no.1 exhaust, and vice versa, we used to do it this way on the monster trucks when i worked with them and it worked great as you can have someone just bump the motor over... Nate
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    also, the distributor rotor should be pointing at the cylinder that you're working on. i always run em 3 times, just to make sure.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That statement is very wrong. A cam with lots of duration will have both valves open at TDC for a short period of time.
  7. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
  8. 1977k5
    May 26, 2003
    9,992
    130
    A cam with lots of duration would have both valves open at the top of the compression stroke? As in just before the plug fires? Sounds wrong to me.
    I understand that there is valve overlap at the top of the exhaust stroke, but that is not TDC.
  9. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    with the valve cover off you can see which valves are in next to the exhaust ports easily.
  10. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    YES! this is exactly what I used and it works great.
  11. rafterman191
    Aug 28, 2006
    54
    Indiana
    That is the way I was going to do it but other stuff I had read stated that exact TDC is hard to find and suggested the opposite method that I described earlier. Nutty how many different ways I have ran into since searching for it.
