SBC year differences
Discussion in 'The Garage' started by GMCJason, Jul 13, 2005.
  1. GMCJason
    GMCJason 1/2 ton status
    Dec 23, 2004
    242
    Longmont, CO
    I have access to a 350 block that I'm considering building for use in my '90 Jimmy. The casting number on the "new" block is 3970014 which seems to indicate it's from the early 70's.
    Are there any reasons why this block wouldn't work in a 1990 TBI truck? I'm concerned about the sensors and such. I'd like to build the engine and just swap 'em when I'm done so I don't have too much down time on my truck.
    If this won't work what years should I be looking for? Anything too old? Too new?
    Thanks.
    Jason
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Everything should bolt right in less the TBI intake, you'll need to do some grinder work on the 4 center mounting bolts. You will need to remove a plug from an oil passage above the oil filter, and you'll need to remove a coolant plug to install the knock sensor as well :)
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    IF he reuses the 90 heads there will be no intake modification needed(yes I know he said less to swap the better). If you use the older heads, they have angled center holes and need to be ground out like noted.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Most of the bigger machine shops would already have a set of those heads , would cost more upfront , but the engine could be built , and then after removal of the old one he could get his core charge back by dropping off his heads .
  5. GMCJason
    Dec 23, 2004
    242
    Longmont, CO
    Thanks guys. I'm still planning but the thought is to build a 383 with Vortec heads. I know I'll need the GMPP intake but that should fix any fitment problems, right? I wasn't thinking about the heads but more the bottom end.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    3970014 will be a two piece rear main seal block which means that your flywheel / flexplate from the '90 motor will not bolt to the old motor's crankshaft. If you have or find the correct flexplate, it will work.
  7. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    anybody got a pic of modifing the heads i need to do that or a write up about doing it
