Scary Clicking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Apr 12, 2000.
    I recently started hearing and feeling a click or bang under my feet when I accelerate. It is almost like something moves under the truck. I have crawled underneath and checked for any loose items...none. It only happens when I start out, from a stopped position. The fact that I can feel it really scares me.
    Anyone have an idea??
    '84 K5
    Chevy in my blood.
  1. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    Check motor mounts, if they are shot and touching the frame, when you take off it will raise off the frame then hit it when the motor comes down. I had that happen to me
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    when you hit the gas the frame torques... maybe your body mount under you foot is rusted or missing, that could make that noise.
    NEVER been stuck... *yet*
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Check the rear transmission mount under the output housing. I don't know about the trucks, but the GM rear-wheel-drive cars had (have) problems with them. My 86 T/A did that too. New trans mount fixed it.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Sounds like defective motor mounts. I had the same symptom on my 74 K5. I replaced em both and bye bye problem.
  5. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    HAD SAME PROBLEM THOUGHT IT WAS THE FRAME BUT CHECK YOUR REAR SHACKLE BUSHINGS THAT WAS MY PROBLEM
  6. Could it be the Body lift, maybe not tightened up? I will check all the mounts/bushings this weekend...Thanks for all the advice guys
    '84 K5
    Chevy in my blood.
  7. Cornfed-90K5
    Cornfed-90K5 Registered Member
    52
    Fresno, California
    An easy way to tell if it is your engine mounts is to open the hood and have a friend lightly push on the gas with the tranny in park and his foot on the brakes if it is your mounts you will be able to se the engine lift. I had the same problem if you change them you should change all 3(both engine mounts and the tranny).
    Cornfed-90K5
    1990 K5 Blazer
    1977 Jeep CJ5
