Scenario Question. What would you do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Feb 16, 2001.
    I have the entire front clip taken off my truck, so I can walk right up to the engine. My question, or Poll if you will, is what would you do while the front was apart? I am going to replace the water pump, fuel pump, raidiator hoses, and the belts. Battery is a piece of crap, so I am going to get a new one also. What else should I check for?
    Oh, I have never replaced any parts since I bought it, so I figured this was a good time.
    '84 K5
    Chevy in my blood.
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Last time I had the front clip off of mine, I installed a new engine! [​IMG]
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    WOW well I guess I would just do as much as I thought would be easyier with the clip off than if it was on and if fundage permits EVERYTHING I could afford to replace.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I would replace the timing chain and gears if it has not been done. While you're in there that far, slap in a new cam and lifters.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'd go over my steering box area with a fine tooth comb and look at installing an ORD brace. With the front end sheetmetal off it'll all be easy to see.
    Oh yeah I'd slap in a 502 Ram-jet if the fundage was there[​IMG][​IMG]
    Rene
  5. Grim-Reaper
    7,385
    Atlanta
    Man while you got it that far apart Timming chain, front seal, and pan seal (you can get the pan off with out lifting the motor), Motor mounts, and every seal that looks like it is seaping I would replace while you can sit on the tire and do it easy. I would adjust the valves while you got the covers off. Might even want to swap the heater core. Fuel pump and lines might not be a bad idea either and same with power steering lines and give it a tune up.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Along with what everyone else said I would also check for any rust on the firewall and repair it and reseal the heater box and any holes throug it. Also I would pressure wash the front frame and suspention and paint it all. Also check your wiper motor mounts and put new ones on if needed.
    Happy Trails
    Wayne
  7. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Check/replace the core support mounts. Get the radiator roded out. Check the wiring harness for chaffing, what about installing some headers? How are your fenders? Do they need any body work or replacing? You might want to spray some rubberized under-coat on the inside bottom of the fenders.
    It's not what you buy, it's what you build!
  8. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I'd replace the motor mounts and definately the battery tray!!!! Mine broke the other day. I never thought about checking it. My battery has never leaked or spilled over. Timing chain is a good idea too. Maybe even check your exhaust studs at the bottom of your manifold.
    creepin' and crawlin'
    Jim
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    While the clip is off, why not install a 638 BBC from Bill Mitchell's Hardcore Racing Products?!?! With a price tag of $13,995.00, thats pocket change to anybody on the CK5 site!!!
  10. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    yeah, i got two.
    --matt
    <A target="_blank" HREF=http://www.geocities.com/shaggyk5>http://www.geocities.com/shaggyk5</A>[​IMG]
