schocks what the f?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by schmuck, Jan 20, 2003.
  1. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    i just swapped out a set of gabrial vst's for some rancho rs 5000 and the truck rides worse now can you belive that schit
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  3. schmuck
    Nov 11, 2002
    523
    had same problem huh
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Been there done that. Put the Gabriel's back on,and get your $$$ back /forums/images/graemlins/cool.gif
  5. schmuck
    Nov 11, 2002
    523
    are any of the offroad shocks any good
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    yes but they're $$$$
  7. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Bilstein
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I just got some Doestch shocks, but haven't had the time yet to put them on.
    They come highly recomended and are affordable.
    -- Mike
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 'off road' shocks that are common and advertised in the rags are all made by Gabriel or Monroe,
    pure advertising hype on cheap shocks
  10. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the doetsch shocks are incredible for the money.
    you can get them through either West Texas Off-Road. or summit.
    have to be honest...summit got the second set to me a few months sooner. and they are under $40
    they are HUGE compared to the ranchos...i took the ranchos off and tossed em.
    Ryan
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I just put the 5012's on and now I'm thinking of replacing them already! /forums/images/graemlins/tongue.gif
  12. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    rancho's suck! i had rs5000's in when i bought the truck and they were all no good. in cold weather they get screwed up and blow cause they're oil filled rather than gas....if you want a good smooth ride look for some gas filled ones
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    OK a small comment here.
    Rancho shocks do not suck.
    Each shock is meant for something.
    The 5000 series is a stiff shock, it's not supposed to ride nice.
    The monroes are good, the gabriels are good, they also have choices of Variable valving, like the rancho has the 9000 series.
    I have the 9000's and they have 5 settings and the new ones have 9 settings from firm to smooth.
    Second, all the offroad shocks that you see in the market are gas shocks, that doesn't mean the gas is what is dampening, they all have oil in them, and the gas is just to compress the oil and prevent it from foaming which makes the shock fade.
    If you want soft shocks ask for soft shocks, if you want them firm for hi speed racing ask for the firm ones.
    If you want the best of both worlds ask for a variable rate, like the VST gabriel, or the sensatrac monroe or the rancho 9000 or similar, you get the point.
    No shock works of gas they all have oil in them, except I thin the nitrogen filled shocks for racing, I am still researching those shocks, but everything else you will find in the market, gas shock or not, uses oil for dampening.
    OK not a small comment. /forums/images/graemlins/thumb.gif
  14. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I ran 5000's for a short time too, they rate right up there with the Pro Comp ES3000's, quite stiff. I second on the Doestch shocks as a good compromise, they perform well and ride nice. Rancho 9000's seem to be doing the trick for quite a few people as well, but most tend to run them exclusively on the softest settings.
    You can always pony up for some Bilsteins and get them custom valved for your application.
  15. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I run my 9000's at 5 on highway and 3 on mild trails, and 1 on rocks.
