School me on 14BFF lockers..
Discussion in 'The Garage' started by Irork, Jan 28, 2007.
  1. Irork
    Irork Registered Member
    Nov 4, 2006
    41
    the great NW
    Ok guys bare with me here. I have recently made the switch from my 94 toyota with a solid axle swap on 36" iroks to my new toy which is a 84 K5. Just put in a nice 3/4 ton dana 44, which i pretty much went through inside and out, warn premiums, you know the deal. Out back i have a 14 bolt ff. Now that i have it in solid workin condition, pretty much turn key. It time to add a locker to the 14 bolt. I plan on leaving the front alone for awhile. My question is, what kind of selection do i have for the 14 bolt. Ive found a detroit and thats about it. I drive the k5 on the rainy, snowy, ugly days to work and back(to keep my airbagged silverado clean and in the garage:D ) Im tryin to stay away from the detroit just for the simple fact of me driving on the street. Ive been told that they make lockrites for this axle... but some some stupid reason i cant find anywhere to order them... i dont really want to make the 2 hour drive to the nearest 4wheelparts. From the sounds of it though the lockrite would work well for me, so.... where can i find them. I know this is the ultimate newb question... but im a newb so it kinda goes hand in hand:haha: Any help would be much appreciated. Thanks guys
    and heres a pic of the blazer
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The Detroit and lock-rite will perform basically the same. Your only choice for a selectable locker is an ARB ($$$$).
  3. Irork
    Nov 4, 2006
    41
    the great NW
    ya im not in the situation for droppin dollars on a arb at this moment. college kid money..... with 2 trucks, the k5 being the cheap one= not alot of extra cash
  4. wheelingdrummer
    wheelingdrummer 1/2 ton status
    Jun 9, 2005
    285
    Boulder, Colorado
    My Detroit has rarely locked up on the steet for me, if that is what you are worried about.
  5. K-5 Bomber
    K-5 Bomber 1/2 ton status
    Aug 20, 2006
    108
    Northeast California
    I'm in the same boat as you are. I have ice and snow here from time-to-time as well. My main concern is getting pitched over a nasty embankment on black ice while I'm driving on the mountain highways:yikes: I've been considering the lockright but I'm still concerned about overall highway safety. Anyone got any experience with such a driving condition?
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    thats a really nice looking rig.
    I ran a detroit in my 14FF with 35" boggers on the street. rain, snow, ice and dry pavement. never had any problems. the trick is to drive more cautiously when it is bad out. the detroit was really easy to install. I'm going to assume the lockright is almost exactly the same as there is only really one way to do it. thats if they actually make it. the inside of your 14FF carrier is not like other carriers. it is 2 peices that bolt together.
    to install the detroit you need to remove the carrier. split it in half, take out the spider gears, drop in the detroit. bolt the case back together. there is a wing nut, washers, and a long bolt that holds the detroit together until you get the case back together. remove the nut, bolt and washer. install the carrier back in your housing.
    no real gear setup required. the bearing are held in by side to side adjustable collars.
    you do not even need to jack the truck up to pull the axle shafts. unbolt them, slide them out a few inches. probably one of the easier mods to do to your truck that looks hard until you do it.
  7. K-5 Bomber
    Aug 20, 2006
    108
    Sounds good. But what about when I'm driving down I-80 and round a curve where the snow has melted and then refrozen on the highway...and I'm doing 60? How are they then?
  8. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    hold on.:eek1:
    seriously though. you should drive slower when it's bad out. also the detroit is designed so that it locks up when you are on the gas. if you let off the gas then the locker should disengage. at 60 mph all 4 wheels are turning at the same speed so to get the locker to have a big effect you need to gas it.
    a locked a rear is going to have more profound effects at slower speed and in tighter turns. I-80 is an interstate highway. I know because it runs by my neck of the woods. the curves are pretty gentle compared to smaller roads.
    think of it this way. if you spin one wheel now, you will spin 2 wheels with the locker. just do not drive in a manner that would break the tires loose.
    you will get there eventually, slow down and show up in your truck or drive as if it's dry out and arrive in a casket. not trying to start a fight, but it always amazes me to watch people speed in the snow.
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    No matter what locker you get go out on a less traveled road or parking lot and mess around a bit. The locked rear end behaves diffrently than an open diff. Once you realize the differences, driving in said weather conditions will be no problem. Also I think a lock right would probably be alright in a 14b but I think a detroit will probably have slightly better behavior
  10. the general
    the general Registered Member
    Oct 2, 2004
    96
    prinsenbeek(the Netherlands)
    i am thinking of buying a 14 bolf ff , and then put an ARB airlocker in it, do you guys now the partnumber of this ARB locker?(its for a 4.56 or 4.88 diffratio) i now have 4.88 diffs with ARB lockers (dana 44+ GM 12 bold combo) but i am thinking too put 4.56 in it too drop the rpm,s a little (now 2600rpm/60 miles an hour)
    thanks !!!!
    Patrick
    The Netherlands.
  11. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    i have had full locked 14ff before in truck with 38s. it was good for traction . but when we got 2" of snow or more it sucked. always wanted to kick out in the rear.
    i had a factory gov lock in the rear before the detroit and loved it. it was open till 1 wheel spun. but with gov lock you need to know how thay work and how to lock them in. or thay can blow up.
    the strongest gov lock is the 14ff unit.
    i still run that same gov lock in my dd 2x4 truck to this day. its been great and never realy let me down at all. when i needed her she was full locked and both tires spinnin. but every day drivin she was nice and open diff.
    if it was me and only some off roadin and mopstly dd . i would go gov lock unit. thay can be had cheep on ebay.
  12. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    did gm call them the "limited slip"?
  13. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yes.
  14. Irork
    Nov 4, 2006
    41
    the great NW
    Thanks for the quick responces!! Youve all talked me into the detroit i have no problem with driving cautiously in the bad conditions.... as long as when i get off the beatin path i have the traction i need to get it done... or "git er' done"! Now my next question is who has them for the cheapest haha... im a cheap SOB:D
    thanks again for the insight and for the compliment on the blazer gmc4cw
  15. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Sweet!:D - Thanks
  16. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    you want us to do everything.:D I bought mine a long time ago(8 years ago) but the cheapest place was Hoaks 4wd here in Pa. I called all the places that advertise in the magazines and all the local speed shops. Hoaks beat everybody even with shipping. At the time I did not have internet access. now if I had to buy one it would take me a week to find the cheapest place.
    here is their contact info.
    Hoaks Four Wheel Drive
    815 Hellam Street
    Wrightsville, PA 17368
    717-252-3602
  17. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    your neck of the woods is about 3k miles away. :wink1: the terrain might be a bit different there. :)
    to the original poster - what part of the NW are you in?
  18. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A few friends and I ordered from Complete Offroad just last month. Two of them are now Detoited on their DDs... one is a 2wd. :D
  19. mendo
    mendo Registered Member
    Oct 22, 2006
    37
    Santa Barbara, CA
    I had a detroit in the rear before and it popped and made crazy loud noises like the axle broke in half. Other then that it was great though, and in snow you really need to be careful. Sorry for the highjack but are those 37x13.00 Boggers? I want to get some of those for my K20 but have never seen them on a rig before, do you have anymore pics maybe from the front so I can see how wide they look. Thanks
  20. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I picked up my detroit off of ebay for 300 hundred shipped, brand new in the box. Keep searching....youll find a good deal.
