school me on bed mounted radiator
Discussion in 'The Garage' started by 79mudder, Jan 24, 2007.
  1. 79mudder
    79mudder Registered Member
    Aug 25, 2006
    68
    Bonesteel
    i use my blazer for alot of mudding tell me the pros and cons of putting it in the rear of my blazer . what radiator should i use and fans? pictures would be great too. i might not know what iam talking about but i think it would run alot cooler wiith more water in the system tell me everything you know. thanks.
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    4 core, electric windstar fans. then use aluminized pipe to run the length and use hoses...
  3. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    what problems will i run into with it mounted back there?
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Bending aluminum tubing sucks. You'll need a port on the water neck to let air escape. Burp it!
  5. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    what do you mean by useing aport and what does it do? or how does it let air out and not water? i really dont know too much about this , as you guys can tell. thanks
  6. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Be like a brake bleeder screw ... open it up, pressurize the system somehow to blow the air out, then close the valve or cap or whatever when the fluid is solid.
    -- A
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I just did this not long ago on my rig. Its a trail only rig. I used sch40 1 1/4" water pipe. I went that route because its cheap and it should hold up to abuse very well. Im using the stock radiator mounted behind my cab with 2 taurus fans. The one time that I have wheeled it I only needed one fan on, mostly cuz the other one fried. It stayed at 180-190 the whole weekend. Well see how it holds up during the summer.
    As far as what everyone is saying about burbing the system. If you have air trapped in the system it will over heat very quickly. When I fill mine I have to undo the upper hose at the motor and stick a screw driver in there to let air out. This has worked the last 2 times I had to refill it.
  8. dremu
    Feb 27, 2000
    15,968
    461
  9. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I dunno if that would hold up. If I had time I would graft on another radiator fill cap into the hardpipe. That way I could fill and burb at the front. Summit sells something like it that you can put in with rubber on each side, but I dont have that kind of room.
    Another benifit of doing this was that I could fit my winch behind the grill.
  10. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    thanks for the replys anything else i should consider?
  11. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Basically for burpin the system, all you need is something you can open up at the highest point at the engine. If your water neck is the highest, you can find a waterneck that has a port in it already. Screw in a plug. Loosen it to let air out and call it a day.
    If your hose goes up from there, you can put a steel tube in at the high point with a NPT fitting and the same plug. Either one is pretty easy to do.
    Start the engine up and have the port open, When water starts coming out close it up.
  12. 79mudder
    Aug 25, 2006
    68
    Bonesteel
    i got the pipe and going to try it out this weekend thanks guys.
  13. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Probably a no brainer but worth the mention, don't try to open it hot! I've been there and it aint no fun! Keep it safe
  14. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
