school me on cooling fans
Discussion in 'The Garage' started by Cornfield creations, Feb 26, 2007.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I have the stock clutch fan. It seems to not be pulling enough air through the radiator to keep my new engine cool enough. Would a flex-a-lite straight fan do better with the spacer to put it closer to the radiator?
    What are the pros and cons on a straight fan?
    Would an aux. electric pusher fan help any?
  2. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    What type of truck ? Is there a radiator cowling ? Is the clutch fan new? Did you change your axle gear ratio?:dunno:
  3. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    its a 79 k-5, I had a stock 350 in it that always cooled real well. Newer 4 core radiator, new heater core. I just put in a 350 ho, and it runs a little warmer than I'd like. I know when it gets hot outside and running AC its gonna run hot. The clutch fan is older but still has good drag and is tight.
    I was just wondering if a straight fan would draw more CFM through the radiator, and what are the down side to running a straight fan?
  4. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    If you've got a little spare cash do what I did and slap 2 14" electric fans on it with a temperature switch and call it done... add a toggle switch if you plan on doing water crossings.
