School me on front leaf springs
Discussion in 'The Garage' started by Eric M., Mar 13, 2006.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    73 to 87 stock fronts leaf springs:
    -Are they all interchangable, 1/2, 3/4 and 1 tons?
    -Is the stock lift any different between 1/2, 3/4 and 1 tons?
    -Are the spring rates any different between 1/2, 3/4 and 1 tons?
    -Do they all have the same number of leafs?
    Thanks,
    Eric M.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    From what I can tell the 1973 to 1991 front leaf length is the same between all three ratings but the number of leaves ranges from two to three depending on the spring package.
    I have seen many Blazers with a three leaf pack and than I had a 1983 Crew Cab Dually with a 454 granny 4-spd and over loads in the rear and it inly had two leaves up front . That truck actually looked like a 2WD when I bought it because the front springs were in such a negative ( more so than they are suposed to be ) arch.
    I am sure the rates are different for various trucks but the two & three leaf front packs seem to be what was offered.
    Tom
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    x2 all same length 2 or 3 leave packs and i dont think there is any differant rates to the 2 and 3 leave packs.
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks!
    Eric M.
