School me on govlocs
Discussion in 'The Garage' started by lochenjons, Apr 16, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I've read a lot of posts about gov-locks on here, and from the sounds of it it's like a limited slip but it trys to be smarter than that? Or is it more than that? How does it work? What makes it weak (i think I read its the carrier?)?
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    A simple search will turn up more that you ever wanted to know.
    To quickly answer your question...its not like a "smart" posi. Its an auto locker....much like a detroit or lockright it. It is open until there is a difference in tire speeds at which time it locks up. The problem isnt with the weak carrier, its with the locker itself. They mainly blow up because they will allow one wheel to start spinning really really fast and then try to lock the other side in. I know with my detroit...it takes maybe a 1/4 of a tire turn at most and then lock. Not so with the gov lock.
    -Harrison
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,031
    1,347
    Kzoo, Mi
    And the problem mostly lies within the 1/2 and 3/4 ton non full floaters.
  4. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Yeah I'm not really worried about breaking anything. I'm mostly wondering how it works I guess
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Picture a clutch type limited slip. That is what my blown 14bff looked like in general.
    Now picture that the part putting the spring load on the clutch pack has a wavy cam surface on it. There is a plate with a matching cam surface on it butted against the first. This first plate is splined to one axle shaft while the second is not.
    One of the side gears has a little set of spur gear teeth around it's OD. These drive a tiny spur gear on a shaft in the diff case. There is a set of flyweights on that shaft.
    If that side gear spins fast enough, relative to the diff case, those flyweights fling out and grab notches in that second plate, locking it to the case. That causes those cam surfaces to increase the pressure on the clutch pack, effectively locking up the diff.
    The problem is not in the idea as it is a great idea. The problem is in the execution of the design. Those little spur gear teeth are just too small for the load put on them.
  6. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Sweet thanks, that was what I wanted to know for the most part
