School me on oil pan gaskets
Discussion in 'The Garage' started by dremu, Feb 4, 2007.
  1. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    Also on the bigblock, should prolly replace it all while I'm in there.
    I see they come in different kinds, more than one piece, one piece, etc etc.
    What's good, what's not, what kinda goop do I use, etc?
    -- A
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    always used one piece units when i've done them, and a small amount of silicone on the pan to hold the gasket in place on installation and a small amount on the bottom of the block at the mating surface... a thin film...
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    X2, the only pan gasket on my old small block I had no trouble with was the one piece rubber gasket. It has steel inserts in the bolt holes to keep it from being squeezed too hard, and the set I got even came with new bolts. Pretty sure it was Moroso, but I'm not 100% on the brand.
    Rene
  4. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i have always used the 2 piece units, i usually just buy cork cause its cheapest. and i goop the living crap out of it, both sides!! that way they dont leak.....ever.
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    X3 one piece with inserts. can't go wrong with that setup
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    x4 on single 1 peice. wow is all i can say.
  7. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    1 piece, and put a dab of silicone where any 2 pieces of metal come together, like the timing cover and the rear main cap, other than that install it dry.
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Permatex Ultra Black is bada$$. Don't get it on your clothes though,it will not wash out. Used it on my whole motor.
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I tried using the 4 piece cork sets that you can get for about $5 cause it was cheap. after about 2 hours of messing with it I went back to the parts store and got a one piece. dont know the brand but it came with new oil pan bolts, the one piece gasket and some plastic studs that you screw into the corners to hold the gasket and oil pan in place while you put the rest of the bolts in. cost about $30 and took 15 minutes to put in and doesnt leak. thats the only way Ill do it from now on. the extra money was well worth it to me.
  10. Seafarer76
    Seafarer76 1/2 ton status Premium Member
    Apr 10, 2006
    340
    Las Cruces, NM
    i used the Felpro Permaseal I think. Its a blue rubber one piece with the inserts. It even came with these nifty little plastic things that thread into the corner bolt holes. Then you slide the gasket over them and then the pan. They hold the gasket and pan in the proper place so you can bolt it into place under the truck without trying to hold the pan up while threading bolts. They worked so well, they are in my tool bag now.
  11. Storm Trooper
    Nov 24, 2000
    4,640
    I've built and had many motors a part and put them together.
    I always use permatex high tac spray for my gaskets and let them sit for a day or two. Never have a leak even with the cheap gaskets.
    You still need the silicone at the timing chain edges and at the back corners of the rear main but it works awesome as long as you don't over toque them and do them even and alternate tightening like a set of heads.
    Also, use the high temp silicone (orange or red). Rubber gaskets should basically be put on dry or they'll push out. If you really want extra protection, you can also run a small bead of the silicone on the outside edge after tight.
