School me on tube
Discussion in 'The Garage' started by BLZN4FN, Oct 16, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok I need some help here. Can someone tell me what kind of tube is out there and the diffence between them is. In basic term.
    I want to make a set of tube doors but dont know what to look for like pipe,dom,ect....
    thanks
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    dom= drawn over mandrel tubing. its some of the strongest pipe.
    you can use regular pipe or tubing for doors. it is welded together and it has a seam down the middle on the inside. not as strong unless you spend an arm and a leg for some schedule 40. just get something that is about 3/16" thick or so for doors. use only DOM for cages.
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    HREW tube is Hot Rolled, electrically welded tubing. Usually mild steel, although it often comes in decent material like 1018.
    DOM, starts out exactly like HREW, then is drawn over the mandrel to tighten up the tolerances. Usually same grade or better than HREW. If the sizes are equal the strength differences aren't that astounding IMO. Yes, DOM is also welded seam tube...the welded seam is just a lot harder to see.
    All tube is defined by the outside diameter. Example: 1.75" tube is 1.75" outside. The thickness of tubing is given as "Wall thickness" EG: .120" wall
    All pipe is defined by the inside diameter and even that is pretty loosely adhered to. 1.75" pipe should be near to 1.75" inside diameter. The thickness of pipe is given as 'schedule'. EG sched 40. Many steel catalogues will have a thickness table telling you the exact wall thickness for any given pipe size and schedule.
    The problem with pipe is there are a lot of grades of pipe, and you could inadvertantly get something not well suited to cage or door construction.
    Rene
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If it is just for tube doors HREW is fine. Most people around here use HREW for cages. My cage and tube doors are both HREW.
    Harley
