school me on u joints
Discussion in 'The Garage' started by 78Suburban, Jul 10, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm thinking with my new lift, the angles may try to eat a u joint.. so I figure it would be nice to have a spare or two, or maybe even go ahead and replace them.. How much money should I look to spend, and what brand? what part number would I need?
    I have a corp 10 front and 14ff rear, th400/203, all factory parts as of now..
    I'm really not familiar at all with u joints, so any basic info would be great!!
    thanks,
    James
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Front joint is a 1310 and the rear joint is a 1350. As far as price I do not know as I have a conversion joint in my shaft and I have only purchased an S44 joint:o .
    Ira
  3. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    Im right behind you with all these questions
    Im going to change the u joints I have the 10bolt 12bolt combo are they the same as his sub?
    thanks Shawn
  4. sandawgk5
    Oct 28, 2003
    6,881
    Front joint is but not sure on a 12 bolt I have only seen pictures of those things:D
    Ira
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    12 bolts are 1310 ( some 4 speeds were 1350 , had one ) . 10 bolt rears are s44 ( simmilar but NOT 1330 ) .
  6. NoReGrEtS
    Nov 7, 2005
    848
    so if the front and rear are the same could I use a front cv on the back in between my slip yoke a shaft?
  7. 87_k5_silverado
    87_k5_silverado Registered Member
    Jul 23, 2004
    24
    Jim Thorpe, Pa
    If i am not mistaken there was a post on here a while back with a photo of a Spicer tool (basically a tape measure)...that you just put the joint up to that and size it up.....i just can't find it. And my lazy arse didn't print it out:(
  8. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I have that spicer tool......oh my god its a magnet.....on the side of my toolbox at work. measures from 13xx upto 1880 series ujoints.
  9. NoReGrEtS
    Nov 7, 2005
    848
    where did you get this tool at?
  10. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    A normal tape measure will do just fine...
    1310: 3-7/32 X 1-1/16
    1330: 3-5/8 X 1-1/16
    3R or S44: 3-5/8 X 1-1/8
    1350: 3-5/8 X 1-3/16
    1410: 4-3/16 X 1-3/16
    Off the top of my head, I think they should be right.
  11. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Local driveline shop. very common. One side sizes yolks other side is joints. Handy to have.
  12. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    took a pic of it...........just 'cause.
