school me on water passage ways
Discussion in 'The Garage' started by 78Suburban, Feb 15, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    My old stock manifold had water passages in the rear of it. The block has water ports in the rear. The edelbrock performer EPS manifold I am about to install has no rear water passages. I had it on my old '66 283 for a long time, which also has water passages in the block. WHY IN THE WORLD does edelbrock not put rear water passages? I have a hard time understanding how the coolant will still flow?
    Thanks,
    James
    PS: there is a bunch of mineral buildup and gunk in the water ports in the block, and a bunch of carbon chunks built up in the exhaust crossover.. yuck :eek1: that old manifold is HEAVY!!!!
  2. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    It goes through the block, up into the heads, and forward. It's fine.
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Cool. Wonder what inspired Ebrock to make it flow differently than the OEM setup?
    thanks,
    James
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i have seen some of the stock intakes not have a cross over in the rear, it might have somthing to do with keeping the manifold cooler to keep the fuel cooler
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    that makes alot of sense really.
    Does anyone know how much one of those SOB's weigh's stock? i thought I was gonna bust a gut trying to lift it outta there :crazy:
    thanks,
    James
  6. dyeager535
    26,979
    As mentioned, GM did go back and forth with having a crossover back there over the years.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I welded bosses onto an intake and brought the coolant fwd to the front crossover. My idea was to see if the engine became less prone to detonation. Those rear cyls get short changed when it comes to cool coolant. It did make a difference.
    Were I to do it again I'd do it on the under side of the intake. Those tubes, even though they were stainless, radiated a lot heat and I had to make a HUGE (valve cover to valve cover, full engine length) isolation plate to keep the heat out of the carb.
