School me people
Discussion in 'The Garage' started by Randy92782, Apr 8, 2007.
  1. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    ok so i see alot of people are running hummer wheels. how come? am i behind times? is there a trick to them that i don't know? fill me in please and keep in mind i'm not a member and cannot see pics unless the are jpg's or w/e. just needin to know if i should look into a set. thank yas
  2. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    ok so i found out i can't see jpg's. post whatever it is i can see
  3. JKLJKL
    JKLJKL Registered Member
    Apr 6, 2007
    7
    MO
    if you are talking about h2's i think its for looks otherwise i wouldnt know
  4. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    the H1 hummer rims are a 16.5 inch rim that is a double beadlock design. There is a magnesium ring/runflat inside the rim that allows the innner and outer bead of the tire to be squeezed inbetween the magnesium piece and the lip of the rim. The rim itself is in two seperate halves and you basicaly bolt them together. The draw backs are that it is a narrow rim 8 or 9 inches and the stock hummer back spacing is really large so most cut out the original center and press or weld in a new center with less backspacing. There are also a lot of people who replace the magnesium runflat with a PVC insert that is lighter. A lot of people run them, because they are a cheap and readily availible. There isn't many options for 16.5 beadlocks, but lots of 16.5 off road tires. Check out www.USA6x6.com for some more info.
  5. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    thanks man will do
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  7. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ready mix...did you recenter your wheels? or did you just use the wheelspacers to eliminate having to do that?
  8. readymix
    May 30, 2004
    6,706
    26
    Spacers
  9. waywest
    waywest Registered Member
    Feb 5, 2007
    11
    Marana az
    What size spacer did you use?I plan on doing the same.
  10. readymix
    May 30, 2004
    6,706
    26
    2" all the way around. I know there is at least one pic of them installed in the link I posted.
    I got them from OffRoad Overstock. Best price you will find.
  11. readymix
    May 30, 2004
    6,706
    26
