School me please.
Discussion in 'The Garage' started by 1-tonmudder, Aug 31, 2006.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I have a 500ci caddi motor with a quadrajet carb,and I am wanting to put propane on it.What all do I need,and any help pointing me the right direction for parts would be appreciated.
    Second,is anybody running dual piston rear calipers on a FF 14 bolt.If so what caliper's are you using and where did you get the bracket's.
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    have you checked out www.cadillacpower.com/forum/ ?
    iirc, shiftless (the mod over there) had talked of propane. however I'm not sure if anyone over there has posted up on whether or not he's actually running propane yet.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    What are you looking for in rear calipers? Are you thinking of wilwoods or something similar, or?
  4. 1-tonmudder
    Apr 24, 2005
    3,052
    Some sort of Ford twin piston calipers,maybe a 70's F-250.
  5. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Those are going to be tough if the stock bracket doesn't work. I'd suggest looking elsewhere for calipers.
    Why do you want a caliper with such a large piston area? Unless the fronts are absolutely huge or you're running two of the GM calipers per wheel you probably won't be able to get the system to balance very well.
