SCOOBYDANN or anyone else with ORD and Springer Shackle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BogginChevy, Jan 15, 2002.
  1. BogginChevy
    BogginChevy Registered Member
    May 18, 2001
    14
    Did you say that you got an additional 2" of lift by using ORD's shackle flip bracket in conjunction with Marv Springers kit with 4" lift springs giving you a total of 6" of lift? Im sorry if you already told me but i want to make sure i get everything right so i don't buy something i cant use. I hate to keep mailing Marvin, he must be pretty busy.
    Thank You,
    Ryan
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    If I got the spring pack that he sells to everyone i would have had 4" of lift, but I wanted 6" of lift so he added a leaf at the botom to give me the 6" of lift I wanted, so no the ORD did not give me an extra 2"
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, 14ff, (soon to be- dana 60, flatbed,and 39.5" TSL's)
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Why even bother with the ORD flip if your gonna run Marv's setup? The Springer Suspension eliminates the need for a flip (and is, itself, a flip plus swing-arm)..
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I second the motion, i still haven't gotten to "test" it so i would go w/ the origional
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Iv got Marvs set up with the stock spring hanger .I ended up with 6".I added a few leaves to the bottom of the F150 spring pack to give me a little bit more.Running the Springer flip brackets with your stock hangers will save you alot of work and money.
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I saw the Springer setup in person for the first time last week on FRIZZLEFRY's rig and it flexes like a MuthaF'er.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  7. BogginChevy
    May 18, 2001
    14
    ive already got the shackle flip in conjunction with 4" lift springs. Im trying to come up with 8" of lift while running marvs setup. SkyJacker makes 6" lift springs for f150's (i was told they have the best flexing springs? Anyone second that?) I could throw an add a leave in there for 8", guess thats my only option.
    -Ryan
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, just like most flips, Marvs will give you around 4" of lift if you install the swing arm level. You can adjust the arm up/down a bit to fine tune ride height but you can't go very far. I would think that all you need would be the 4" Ford lift springs plus Marv's setup and call it done for 8" total. If you need an extra inch or so, you might be able to get it by adjusting the swing arm down (not ideal since you are effectively using up travel), use an add-a-leaf (probably going to give you 2" or so), or make/buy a zero-rate add-a-leaf (see ORD).
    Russ
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, it just occurred to me. Due to the Springer swing arm's offset above the bolt/bushing, you may not be able to use it with the ORD flip. I think it will hit.
    Russ
  10. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have the springer setup w/ the ORD. he made a special drop bracket for that purpose. i have a pic of on the website below under "project scooby"
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ahhh, looks good. He really does some quality work doesn't he...
    Russ
  12. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Haveyou seen the fun buggy---that thing is cool!!
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've only seen pictures so far but, yes, it is very cool. I'm too lazy to even start on something like that.
    Russ
  14. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Gents,
    Sorry I haven't responded sooner, but I had a 3 day date with the flu..! Yuk...
    Anyway, the springs can be built (you or I) to 4" to 6" lift over stock. The "standard" way of doin' it is to use the original frame shackle bracket and just "bolt on" my system. But many of you, like ScoobyDann, have already installed the ORD Flip. For this reason, I created a "one off" set of drop brackets for ScoobyDann's truck, and his truck is the only one like it so far.
    So, to answer the ? which way is better.... I'd say that it's more proven and easier to use the original frame bracket. So, Ryan.... if you didn't throw your old ones away when you installed the ORD flip, you could actually bolt them back on. If that's not an option, then I could fabricate another set like the ones on ScoobyDann's truck.
    I couldn't ever find anyone who made aftermarket "lift" springs for the F-150. Haven't looked in a couple of years though.... What is the nature of SkyJacker's stuff? new springs or add-a-leafs?
    Marv
