Scored a Dana 70 ~ Need some help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 54inches, Jan 6, 2007.
  1. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    I scored a Dana 70U SRW 35 Spline 4.10 for $150.
    Now, I am selling my 14 bolt, but I am trying to put the disc brake conversion onto the Dana 70.
    It will almost work.
    Check these pics out:
    As you can see in the pictures two of the bolts line up, but two are offset.
    Q#1 Should I modify the brackets or the housing? or buy new brackets?
    Q#2 Should there be a problem with the fact that the inside of the bracket does not set flush with the housing like it did with the 14 bolt?
    Thanks in advance!
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    diffrent brackets if i recall correctly.
  3. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    Talked to GLO today and will be ordering some soon.
