Scored a hydrolic clutch setup today
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JohnSPledg, Apr 28, 2003.
  1. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    I was able to get everthing from the pedal to the throwout bearing for under $100. The only hose that is bad is the one from the resevoir to the master cylinder. Now all I have to do is figure out what clutch I am going to put in it, start my body work, paint it and put it all back together. That should only take a few months....
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    cool deal, i got mine for under $60.00 /forums/images/graemlins/laugh.gif make sure you use a DOT3 approved hose for that. or you'll end up with hose particles inside your system. DOT3 fluid eats through regular plasic hoses. The dealer wants like 20.00 for that 10" hose. shop around and if you find another source let us know.
    ARQ.
  3. dshull
    dshull Newbie
    May 19, 2003
    4
    I am considering a hydraulic clutch conversion for my 72 blazer - what applications are easiest to convert for this use?
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    i belive that 87+ trucks came with the hydro clutch. I got mine from an 87 3/4 ton truck and some new parts from an 89 1 ton. they should all be the same.
    ARQ.
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Where/how did you mount the master?? Is it next to the booster or elsewhere?? I need to install a clutch master on my '72 Sub because of the Cummins that is going in it, and was just wondering how others have accomplished it already.
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I mounted my master upside down. I'll look up some pics and post them or email them to you. I mounted it between the fues box and the steering column, right above the horn button.
    ARQ.
  7. mosesburb
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Sounds great /forums/images/graemlins/thumb.gif!! If its ok by you, please post them instead of email. The last couple times I got pictures emailed to me it crashed my mail service for a couple days. Thanks a bunch /forums/images/graemlins/grin.gif,
    Nick
