Scored On A Dana 60!!!!!!!!!!!!!!!!!!!
Discussion in 'The Garage' started by JUNIOR-K5, Feb 2, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just got off the phone with a guy who is going to hold a D60 for me for $600. Only thing is its a drw and has 3.54 gears what is needed to change to 456 gears:D
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    sure its 3.54? that sounds awfully low for a 1 ton, or was it regeared?
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I've got atleast one with 3.54's
    Nice find by the way
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hmm learn something new all the time, i knew ford did some funky ratios but i didnt think chevy did front 60's with any gears lower than 3.73
  5. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Is it a Dodge front?
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    here we go the d 60 expert him self is here:D where were ya when i had questions earlier:confused::D
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    3.54s are very common in Fords and he never specified passanger drop :wink1:
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Thats why i asked. i assumed it was a chevy front end but i did mention ford put those funky gears in em:wink1:
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    if its a Ford HP axle...you just need the new gears. if its Dodge or Chevy...you need a new carrier and the gears, OR a ring gear spacer and the gears.
  10. 6.2puller
    Jul 8, 2004
    569
    New England
    How does that work? HP and standard D60s use the same carriers. Are the Ford 3.54s specially cut for a 4.56s and numerically higher carrier? "thin cut" gears, never heard of them.
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    or you just get thick gears:rolleyes:
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    great score. word of advice though, unless he's a great friend... don't make him "hold it" for you any longer than absolutely necessary... never know when some clown with $750 might show up and scoop ya... and that would suck.
    DRW is no big deal, you can swap hubs or just run rims with mad backspacing... hummers, custom staz, whatever.
    j
  13. mountainexplorer
    Nov 14, 2001
    4,903
    I just have a bunch of them. I'm no expert. I just bolt them in and go. :D
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Really so youve never messed with em? i find that hard to believe:D
  15. mountainexplorer
    Nov 14, 2001
    4,903
    I've had some apart with outers and shafts out and added a crossover arm. But haven't replaced kingpins or gears and haven't done enough to feel technically qualified. :D
    But anyways... didn't mean to diverge from the original topic.
  16. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Its a chevy d60 its apart with pass. side drop open and guy said it had that gear ratio.
  17. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Good luck. When I got my D-60 the guy said it would be $300...When I showed up it had suddenly jumped to $600 and "someone else was on there way to pick it up"
    -I paid the $600 and got the heck out of there :D
  18. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Sure it's not a Dodge D61F? Check the casting on the pumkin if it says "61F" it could be a spendy diff to get it where it's useful to you. AFAIK the D61 were commonly found under the early CTD truck that had auto's without overdrive...hence the tall gears. The 'tallest' ratio I've ever heard of in a chev D60 is 3.73, and even that is uncommon. 4.10's are most common, then 4.56.
    Before you hand over the cash you should know that most would consider a 61F to be worth substantially less than a 60F.
    Rene
  19. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Alright now you guys got me thinking Im going to look at the d60 tomorrow so what should I look for to make sure its a chevy. Guy told me it was a pass. side drop open with 354 gears is that really impossible or rare gear ratio.
  20. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Anybody?????????????
