Screamin' SBC - 410/425 for sale or trade...
Discussion in 'General Parts for Sale' started by Topdown, Jan 21, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Screamin\' SBC - 410/425 for sale or trade...
    New 600 CFM Holley carb
    New Edelbrock air-gap aluminum intake
    New 180 degree thermostat
    New Trick Flow aluminum heads
    New Aluminum 1.6 ratio full Roller Rockers
    New Comp Cams chromoly pushrods
    NewComp Cams XE248 cam (mild/med lope to idle - sounds GOOD)
    NewComp Cams hydraulic lifters
    New Keith Black hypereutectic flat-top pistons
    New GM "pink" rods
    New Scat crank
    New GM harmonic balancer
    New Moroso 7-qt oil pan
    New Moroso high-volume oil pickup
    GM HEI distributor (not new)
    New water pump
    350-ci 4-bolt main block (bored .030, line-honed)
    All New ARP bolts
    All New Fel-Pro gaskets
    This engine ran like a mother-[darn] and managed to get 12mpg in my 1st gen... You could gain another 5-10 hp & ft/lbs with a 750 CFM carb, but the 600 is about right for street/wheeling use.
    Will trade for a nice running/driving mid/late 80's burb /forums/images/graemlins/thumb.gif
  2. bigslok5
    bigslok5 Registered Member
    Sep 9, 2003
    67
    Wheatland, Ca (northern california)
    Re: Screamin\' SBC - 410/425 for sale or trade...
    Do you have a dollar amount that you're looking for? /forums/images/graemlins/ears.gif
  3. Topdown
    Nov 26, 2002
    2,598
    I have 3000.00 in parts (1000 in heads alone) not including assembly or machine work...
    so I would say somewhere in the 3000 range.
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i can't afford it but if you send me ALL the specs i'll run it through desktop dyno and give the people some numbers.
  5. Topdown
    Nov 26, 2002
    2,598
    I already had it dyno'd... 410hp 425ft-lbs at the flywheel. /forums/images/graemlins/thumb.gif
