screwed up and failed smog
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5geezer, Jul 21, 2002.
  1. k5geezer
    k5geezer Registered Member
    Jul 21, 2002
    10
    Southern CA
    Got labled a gross polluter for failing nitrous oxide emissions. HC was 10-20% of allowable, CO measured 0%, but NO was way high. After failing, did a search on this site and saw recommendatins to get a pre-test. Too late now. The EGR passes all the diagnostics in the GM manual, however, hooked up a vacuum gage to the EGR port so I could read it while driving. The EGR gets vacuum when accelerating but it kicks out during cruise. I guess it kicks out on the smog treadmill test too. No codes show up and timing is set at zero degrees.
    Any ideas what I should look for next? Would methanol or one of the drug store addatives help reduce Nitrogen emissions? Thanks in advance for any replies.
  2. dyeager535
    26,980
    Lowering combustion temps will help with NOx. So will a cat converter. (somewhat) Alcohol will work if it burns *cooler* than gas, but I don't know the answer to that one.
    EGR helps NOx as well I thought by bringing down combustion temps. If you have an EGR problem, you should probably get it fixed. Should be *open* at a steady cruise.
  3. k5geezer
    Jul 21, 2002
    10
    Southern CA
    Does anybody know if alcohol or other fuel additives will help pass NOx with a TBI motor?
