Screwed up my doors.. whats the fix?
Discussion in 'The Garage' started by Ben B., Jun 29, 2006.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I thought there was something wrong with my blazer so i was backing up with the door open looing around and I hit a tree with the door.
    So now it opens too far and it's rubbing my fender...What's the fix? New hinges?
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Are you saying that you backed into a tree and now your tailgate is rubbing on the rear quater panels? That sucks....have any pictures? See how its lineing up.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    HAH I backed up once with my door open.. right into a tree... it bent backwards.. needed a new door and fender... :doah:
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    TRUGGY BUILD-UP!!!:haha:
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    buddy of mine sheared the driver door on his 05 Dodge 2500 in half... that was with a twin post lift and a cummins idling in reverse...
    Can you retype and clarify the original post please?
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    well if I know the question right... as in what I did.....
    when I did this... my door went all the way back and now it worked from the fender to 1/2 way.. I had to use the door to push it back in place... then I could shut it.. but it bent the door end and the fender lip....:crazy:
  7. Ben B.
    Sep 1, 2005
    352
    Central PA
    My door opened too far making it come out of alignment and now it's rubbing on my front fender. I'm sure some of you have done this...
  8. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    still going to have pictures to get some idea of what is going on there. Could need new hinges but then again it may be so bad that the door itself is a little srewed up.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    i believe you broke the top hinge... it holds the door from going to far back.. if you bend it back it could brake.....
